Corrupted PDF in 5.5.2
Hello
I have just upgraded to 5.5.2 and still get the corrupted PDF and JPG messages when I try to open them from my email notification. the last post of this thread indicated that it would be fixed in 5.5.1. Is there more that I should do as well as upgrading?
Thanks for your help
Terry
Terry
Re: Corrupted PDF in 5.5.2
Are you using SSL or a proxy on this server?
Run the following commands and show the output in code wraps:
Also, show us a screenshot of the System Settings page (Admin > System Config > System Settings), showing the Program URL and the External URL fields.
Upload one of the "corrupted" reports on the forum. Thank you!
ip addr
hostname
cat /etc/hostsgrep use_https /usr/local/nagiosxi/html/config.inc.php
/usr/bin/wkhtmltopdf -V
tail -100 /var/log/httpd/error_logUpload one of the "corrupted" reports on the forum. Thank you!
Hello, Thanks for your reply.
This is an offline server that connects to a proxy for updates when needed.
IP Addr
Hostname
System Settings
IP Addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
valid_lft forever preferred_lft forever
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000
link/ether 00:15:5d:03:1c:00 brd ff:ff:ff:ff:ff:ff
inet scope global eth0
inet6 scope link
valid_lft forever preferred_lft foreverHostname
[root@MetNagios /]# hostname
MetNagioscat /etc/hostsgrep use_https /usr/local/nagiosxi/html/config.inc.php
cat: /etc/hostsgrep: No such file or directory
cat: use_https: No such file or directory
<?php
// Copyright (c) 2008-2016 Nagios Enterprises, LLC. All rights reserved.
// Base url
// - do not include http(s) or host name - this is the base from "http://localhost"
$cfg['base_url'] = "/nagiosxi";
// Base root directory where XI is installed
$cfg['root_dir'] = "/usr/local/nagiosxi";
// Directory where scripts are installed
$cfg['script_dir'] = "/usr/local/nagiosxi/scripts";
$cfg['xidpe_dir'] = '/usr/local/nagios/var/spool/xidpe/';
$cfg['perfdata_spool'] = '/usr/local/nagios/var/spool/perfdata/';
// Nom checkpoints
$cfg['nom_checkpoints_dir'] = "/usr/local/nagiosxi/nom/checkpoints/nagioscore/";
// Force http/https
$cfg['use_https'] = false; // determines whether cron jobs and other scripts will force the use of HTTPS instead of HTTP
// Allow for different http port for subsystem calls
$cfg['port_number'] = false;
// Default server, db, connection settings
$cfg['dbtype'] = ''; // this setting is no longer used - use settings below
$cfg['dbserver'] = 'localhost'; // this setting is no longer used - use settings below
// Database connection type
// 1 = persistent, 0 = normal
$cfg['db_conn_persistent'] = 1;
// DB-specific connection information
$cfg['db_info'] = array(
"nagiosxi" => array(
"dbtype" => 'mysql',
"dbserver" => '',
"user" => 'nagiosxi',
"pwd" => 'n@gweb',
"db" => 'nagiosxi',
"dbmaint" => array( // variables affecting maintenance of db
"max_auditlog_age" => 30, // max time (in DAYS) to keep audit log entries
"max_commands_age" => 480, // max time (minutes) to keep commands
"max_events_age" => 480, // max time (minutes) to keep events
"optimize_interval" => 60, // time (in minutes) between db optimization runs
"repair_interval" => 0, // time (in minutes) between db repair runs
"ndoutils" => array(
"dbserver" => 'localhost',
"user" => 'ndoutils',
"pwd" => 'n@gweb',
"db" => 'nagios',
"dbmaint" => array( // variables affecting maintenance of ndoutils db
"max_externalcommands_age" => 7, // max time (in DAYS) to keep external commands
"max_logentries_age" => 90, // max time (in DAYS) to keep log entries
"max_statehistory_age" => 730, // max time (in DAYS) to keep state history information
"max_notifications_age" => 90, // max time (in DAYS) to keep notifications
"max_timedevents_age" => 5, // max time (minutes) to keep timed events
"max_systemcommands_age" => 5, // max time (minutes) to keep system commands
"max_servicechecks_age" => 5, // max time (minutes) to keep service checks
"max_hostchecks_age" => 5, // max time (minutes) to keep host checks
"max_eventhandlers_age" => 5, // max time (minutes) to keep event handlers
"nagiosql" => array(
"user" => 'nagiosql',
"pwd" => 'n@gweb',
"db" => 'nagiosql',
"max_logbook_age" => 480, // max time (minutes) to keep log book records
// db-specific table prefixes
$cfg['db_prefix'] = array(
"ndoutils" => "nagios_", // prefix for NDOUtils tables
"nagiosxi" => "xi_", // prefix for XI tables
"nagiosql" => "tbl_", // prefix for NagiosQL tables
// component info
$cfg['component_info'] = array(
"nagioscore" => array(
"cgi_dir" => "/usr/local/nagios/sbin",
"import_dir" => "/usr/local/nagios/etc/import",
"plugin_dir" => "/usr/local/nagios/libexec",
"cgi_config_file" => "/usr/local/nagios/etc/cgi.cfg",
"cmd_file" => "/usr/local/nagios/var/rw/nagios.cmd",
"log_file" => "/usr/local/nagios/var/nagios.log",
"nom_checkpoint_interval" => 1440, // time (in minutes) between nom checkpoints
"pnp" => array(
"perfdata_dir" => "/usr/local/nagios/share/perfdata",
"share_dir" => "/usr/local/nagios/share/pnp",
"direct_url" => "/nagios/pnp",
"username" => 'nagiosxi', // don't change this!
"password" => 'nagiosadmin', // this gets reset when security credentials are reset after installation
"perfdata" => array(
"rrdtool_path" => "/usr/bin/rrdtool",
"dir" => "/var/www/html/nagiosql",
"direct_url" => "/nagiosql",
"password" => 'n@gweb', // this gets reset when security credentials are reset after installation
"nagvis" => array(
"share_dir" => "/usr/local/nagios/share/nagvis",
"direct_url" => "/nagios/nagvis",
"username" => 'nagiosadmin', // don't change this!
$cfg['demo_mode'] = false; // is this in demo mode
$cfg['dashlet_refresh_multiplier'] = 1000; // milliseconds (1 second = 1000)
// REFRESH RATES FOR VARIOUS DASHLETS (IN SECONDS UNLESS THE MULTIPLIER IS CHANGED)
$cfg['dashlet_refresh_rates'] = array(
"available_updates" => 24 * 60 * 60, // 24 hours
"systat_eventqueuechart" => 5,
"sysstat_monitoringstats" => 30,
"systat_monitoringperf" => 30,
"sysstat_monitoringproc" => 30,
"perfdata_chart" => 60, // performance graphs
"network_outages" => 30,
"host_status_summary" => 60,
"service_status_summary" => 60,
"hostgroup_status_overview" => 60,
"hostgroup_status_grid" => 60,
"servicegroup_status_overview" => 60,
"servicegroup_status_grid" => 60,
"hostgroup_status_summary" => 60,
"servicegroup_status_summary" => 60,
"sysstat_componentstates" => 7,
"sysstat_serverstats" => 5,
"network_outages_summary" => 30,
"network_health" => 30,
"host_status_tac_summary" => 30,
"service_status_tac_summary" => 30,
"feature_status_tac_summary" => 30,
"admin_tasks" => 60,
"getting_started" => 60,
"pagetop_alert_content" => 30, // not a dashlet yet, sits in page header
"tray_alert" => 30, // sites in page footer
// MEMCACHED SETUP
$cfg['memcached_enable'] = false; // should we use memcached or not?
$cfg['memcached_hosts'] = array('127.0.0.1', '192.168.1.3'); // one or more memcached servers
$cfg['memcached_port'] = 11211; // default memcached port
$cfg['memcached_compress'] = false; // use true to store items compressed
$cfg['memcached_ttl'] = 10; // max number of seconds data (from SELECT statements) should be cached
// HTTP BASIC AUTHENTICATION INFO -- USED BY SUBSYSTEM
$cfg['use_basic_authentication'] = false; // is HTTP Basic authentication being used? if so, set the two variables below...
$cfg['subsystem_basic_auth_username'] = 'nagiosxi'; // subsystem credentials
$cfg['subsystem_basic_auth_password'] = 'somepassword';
$cfg['default_language'] = 'en_US'; // default language
$cfg['default_theme'] = ''; // default theme
// available languages
$cfg['languages'] = array(
"en_US" => "English",
/********* DO NOT MODIFY ANYTHING BELOW THIS LINE **********/
$cfg['default_instance_id'] = 1; // default ndoutils instance to read from
$cfg['default_result_records'] = 100000; // max number of records to return by default
$cfg['online_help_url'] = "https://support.nagios.com/"; // comment this out to disable online help links
$cfg['feedback_url'] = "https://api.nagios.com/feedback/";
$cfg['privacy_policy_url'] = "https://www.nagios.com/legal/privacypolicy/";
//$cfg['db_version']=101;
$cfg['db_version'] = 113;
//$cfg['product_version']='2009RC1';
$cfg['subsystem_ticket'] = "12345"; // default - this gets reset...
$cfg['htaccess_file'] = "/usr/local/nagiosxi/etc/htpasswd.users";
$cfg['htpasswd_path'] = "/usr/bin/htpasswd";
$cfg['enable_analytics'] = 1;
// Secure notification %responseurl%
// setting this to 1 will force users to login in the response URL
// $cfg['secure_response_url']=1;
// Globally disable in page help system
// $cfg['disable_helpsystem']=1;
///////// keep these in order /////////
if (!defined('CFG_ONLY')) {
// include generic db defs
require_once(dirname(__FILE__) . '/includes/db.inc.php');
// include generic definitions
require_once(dirname(__FILE__) . '/db/common.inc.php');
[root@MetNagios /]# /usr/bin/wkhtmltopdf -V
wkhtmltopdf 0.12.1.3 (with patched qt)
[root@MetNagios /]# tail -100 /var/log/httpd/error_log
[Sun Aug 26 03:44:16 2018] [notice] Digest: generating secret for digest authentication ...
[Sun Aug 26 03:44:16 2018] [notice] Digest: done
[Sun Aug 26 03:44:17 2018] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Mon Aug 27 09:05:51 2018] [error] [client ] Proxy CONNECT aborted due to timeout, referer: http://metnagios.metrotraffic.seq.its/nagiosxi/login.php?redirect=/nagiosxi/index.php%3f&noauth=1
[Mon Aug 27 09:06:06 2018] [error] [client ] Received HTTP code 503 from proxy after CONNECT, referer: http://metnagios.metrotraffic.seq.its/nagiosxi/includes/page-home-main.php?&=
[Mon Aug 27 11:53:52 2018] [error] [client ] Proxy CONNECT aborted due to timeout, referer: http:///nagiosxi/login.php
[Thu Aug 30 16:22:10 2018] [error] [client ] Proxy CONNECT aborted due to timeout, referer: http://metnagios/nagiosxi/login.php?redirect=/nagiosxi/index.php%3f&noauth=1
[Thu Aug 30 16:22:26 2018] [error] [client ] Received HTTP code 503 from proxy after CONNECT, referer: http://metnagios/nagiosxi/includes/page-home-main.php?&=
[Fri Aug 31 15:18:54 2018] [error] [client ]
Received HTTP code 503 from proxy after CONNECT, referer: http://metnagios/nagiosxi/login.php
[Fri Aug 31 15:18:55 2018] [error] [client ] Received HTTP code 503 from proxy after CONNECT, referer: http://metnagios/nagiosxi/includes/page-home-main.php?&=
[Fri Aug 31 15:19:21 2018] [error] [client ] Received HTTP code 503 from proxy after CONNECT, referer: http://metnagios/nagiosxi/includes/page-home-main.php?&=
One of the reports
Unfortunately I have not been able to upload a file as it tells me it empty and I have not been able to download it to the website.
Two of my commands got stuck together - sorry about that! Instead of running this:
you should've run this:
Can you run these commands and show the output?
Anyhow, looking at your log, it seems like the problem is caused by your proxy. Is the metnagios IP in the no_proxy list? See our KB article on problems with using proxies in XI:
https://support.nagios.com/kb/article.php?id=147
Run the following command and show the output:
cat /etc/hostsgrep use_https /usr/local/nagiosxi/html/config.inc.phpCode: Select all
cat /etc/hosts
grep use_https /usr/local/nagiosxi/html/config.inc.phpAnyhow, looking at your log, it seems like the problem is caused by your proxy. Is the metnagios IP in the no_proxy list? See our KB article on problems with using proxies in XI:
ping MetNagios -c 3Be sure to check out our Knowledgebase for helpful articles and solutions!
Hello
The proxy is only available when needed and not permanently connected.
As per the article you provided the setting were already setup, however to confirm the yum.conf does not have a no_proxy list, but the wgetrc file does and there was a no_proxy list as described including the 10.0.0.0/8 range that this server sits in.
Not sure I understand why this would be an issue with the send of the PDF file however.
I have been trying to send a smtp message from cli but having difficulty with the following
mail -s "Test Subject" [email protected] -a message.txt < /dev/null
I have made some changes to create some consistancy in the naming
The server is now named
ping nagios -c 3
cat /etc/hosts/
ping nagios -c 3
[root@nagios /]# ping nagios -c 3
PING 56(84) bytes of data.
64 bytes from : icmp_seq=1 ttl=64 time=0.033 ms
64 bytes from: icmp_seq=2 ttl=64 time=0.039 ms
64 bytes from : icmp_seq=3 ttl=64 time=0.026 ms
--- nagios.metrotraffic.seq.its ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1999ms
rtt min/avg/max/mdev = 0.026/0.032/0.039/0.008 ms
[root@nagios ~]# cat /etc/hosts
127.0.0.1 localhost.localdomain localhost.localdomain localhost4 localhost4.localdomain4 nagios localhost
::1 localhost.localdomain localhost.localdomain localhost6 localhost6.localdomain6 nagios localhost
[root@nagios ~]# grep use_https /usr/local/nagiosxi/html/config.inc.php
Does the no_proxy list localhost and 127.0.0.1 also?
The no_proxy list for the wgetrc file is
no_proxy=localhost,127.0.0.0/8,172.16.0.0/12,192.168.0.0/16, 10.0.0.0/8
I have found this in the logs when the report is run, can you advise
--2018-09-07 10:26:07-- http:////reports/execsummary.php?reportperiod=last24hours&startdate=&enddate=&host=&service=&hostgroup=POB+Extension&servicegroup=&advanced=1&assumeinitialstates=yes&assumestateretention=yes&assumestatesduringdowntime=yes&includesoftstates=no&assumedhoststate=3&assumedservicestate=6&timeperiod=&locale=en_US&mode=pdf&token=dc4b69f91e2333581912a94c5e8fe65294487910
Resolving ... ::1, 127.0.0.1
Connecting to |::1|:80... connected.
HTTP request sent, awaiting response... [Fri Sep 07 10:26:07 2018] [error] [client ::1] File does not exist: /var/www/html/reports
404 Not Found
2018-09-07 10:26:07 ERROR 404: Not Found.
Hello
Found the issue in the php code.
thanks
thanks
