CHECK_NRPE: Error - Could not complete SSL handshake
desmondlewissmith
Post by desmondlewissmith »
What would cause this error?
Is this a case where I'd need to specify in the /usr/local/nagios/etc/nrpe.cfg and IP address for allowed hosts?
Right now I'm getting CHECK_NRPE: Error - Could not complete SSL handshake for every service monitored.
I'm running the downloaded VMware image.
Plan B is to make Plan A work.
Re: CHECK_NRPE: Error - Could not complete SSL handshake
On the CLIENT computer, I would edit
/etc/xinetd.d/nrpe
service nrpe
        flags           = REUSE
        socket_type     = stream
        port            = 5666
        wait            = no
        user            = nagios
        group           = nagios
        server          = /usr/local/nagios/bin/nrpe
        server_args     = -c /usr/local/nagios/etc/nrpe.cfg --inetd
        log_on_failure  += USERID
        disable         = no
        only_from       = 127.0.0.1 ADD_IP_HERE
add the IP of your Nagios XI machine.
then,
service xinetd restart
If you continue to receive errors, look in
/var/log/messages
on the CLIENT machine
