Can't login LS Server
mwang
Post by mwang »
I meet an issue that the log server didn't let me login in the system. When I run the terminal , it shows below, can someone help me to fix it? Thanks
cdienger
Re: Can't login LS Server
Post by cdienger »
It looks like the hard drive is full. Confirm this with "df -h".
If you're using the vmware image we provided then you can use https://support.nagios.com/kb/article/n ... e-266.html to resize the drive. Once things are running again then I would suggest checking the retention settings and setting up a repository to store old indexes to help filling the drive again. This is covered in:
https://assets.nagios.com/downloads/nag ... enance.pdf
https://assets.nagios.com/downloads/nag ... ations.pdf
