RESETTING CONFIG PERMS FAILED error during nagiosxi install
vy3734
Post by vy3734 »
I'm trying to setup a nagios server. However, i am running into into issue where the E-importnagiosql script is failing with the error message
2018-09-06 13:56:15 (2.04 MB/s) - ‘nagiosql.import.monitoring’ saved [23514]
Sorry, user root is not allowed to execute '/home/nagios/nagiosxi/nagiosxi/basedir/scripts/reset_config_perms.sh' as root on ma209dlvnag001.
RESETTING CONFIG PERMS FAILED!\n
Can you please help me with figuring out the issue here?
Attached the install.log here after executing fullinstall script.
install.log
Thanks in advance.
Re: RESETTING CONFIG PERMS FAILED error during nagiosxi inst
Generally we recommend installing this from /tmp and as the root user
Can you run change to the root user then run the following:
mv /home/nagios/nagiosxi /tmp
cd /tmp/nagiosxi
./fullinstall
vy3734
Post by vy3734 »
Running the installation from /tmp location worked.
Thank you so much for the suggestion.
cheers!!
vy3734 wrote:Running the installation from /tmp location worked.
cheers!!
Great!
Locking thread
