Hello Team,
I have tried to pull the graph from graph explorer but for memory usage I am not able to get % if any options available to get the date in percentage .
But I am getting data in MB so I want data in %
Please let me know if this is possible in nagiosxi ?
Performance Graph
npolovenko
- Support Tech
Re: Performance Graph
Hello, @Mani.Murugesan. There is no such option when using the standard memory check. Although you can see the top memory threshold line on the graph and visually compare it with the used memory threshold line on the graph.
If you want to see memory usage in percentage please consider this plugin instead:
https://github.com/ninoabbate/nrpe-plug ... _memory.sh
