Can't locate Net/SNMP.pm in @INC
bhaskarbabar
Post by bhaskarbabar »
Problem 2
./check_cisco_switch.pl -H **.**.**.** -C ******* -t fan
Can't locate Net/SNMP.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./check_cisco_switch.pl line 15.
BEGIN failed--compilation aborted at ./check_cisco_switch.pl line 15.
I am receiving this error when i fire this command "./check_cisco_switch.pl -H **.**.**.** -C ******* -t fan"
Re: Can't locate Net/SNMP.pm in @INC
Try installing the perl-Net-SNMP package.
On CentOS:
yum install perl-Net-SNMP -y
Let us know if this helped.
bhaskarbabar
After exicuting given command get below message
Loaded plugins: refresh-packagekit, security
Setting up Install Process
Ol6_latest | 3.0 kB 00:00
kernel_upgrade | 2.5 kB 00:00
ksplice-uptrack | 2.5 kB 00:00
No package perl-Net-SNMP available.
Error: Nothing to do
The package is provided by the epel repo. You probably don't have it, so try:
yum install epel-release -y
yum update -y
bhaskarbabar
Thanks for info.
But perl-Net-SNMP was already installed.
After Rebooting server it worked.
Thanks for your reply.
I am glad your issue has been resolved! I am closing this topic. If you have any further questions, please start a new thread.
