We are trying to use check_domain to check domain expiry for .jp, .co.jp, .sucks, .com.ar, .pl etc.
However, there is no any WHOIS server who can provide domain expiry info of above TLDs.
Can you please help?
AKS
Not able to perform domain_check for specific TLD
Re: Not able to perform domain_check for specific TLD
Which plugin are you using? Where did you get it?
You may have to modify the plugin to add all the different possibilities if they return results in a not-expected format.
