Python error executing command
JTWilkins
Post by JTWilkins »
I'm trying to send a notification to Telegram.
I've got a python script that I am calling to send the notification but getting a module import error. I've tried installing the missing module but not having any luck.
Here is my code for the command.
  command_name     notify-service-by-telegram
  command_line     /usr/local/bin/nagios_telegram.py --token $USER4$ --object_type service --contact $USER3$ --notificationtype "$NOTIFICATIONTYPE$" --servicestate "$SERVICESTATE$" --hostname "$HOSTNAME$" --hostaddress "$HOSTADDRESS$" --datetime "$LONGDATETIME$" --output "$SERVICEOUTPUT$" --servicedesc "$SERVICEDESC$" --servicename "$SERVICENAME$"
This is the code for the python script that I am using. https://github.com/dariomas/nagios_tele ... elegram.py
I have tried to execute the script outside of Nagios and it was working so why it won't load the modules I don't know any help would be appreciated.
Jonathan
Re: Python error executing command
When you test it outside of nagios, are you running it as the nagios user?
su nagios
It is possible that when you added the missing packages you added them to a path that isn't accessible by the nagios user.
