Recovery alert after no warning alert
amprantino
Post by amprantino »
I have configured a service as follows:
it will send an alert only to critical & recovery states.
However, I am receiving numerous recovery alerts but no critical.
The service indeed is changing states between OK and Warning:
        host_name                       HOST
        service_description             Service_Name
        is_volatile                     0
        max_check_attempts              2
        normal_check_interval           2
        retry_check_interval            2
        contact_groups                  net-admins
        notification_interval           240
        notification_options            c,r
        check_command                COMMAND
Should I receive a recover mail although I haven't received a critical alert for the service?
The documentation says:
notification_options: This directive is used to determine when notifications for the host should be sent out. Valid options are a combination of one or more of the following: d = send notifications on a DOWN state, u = send notifications on an UNREACHABLE state, r = send notifications on recoveries (OK state), f = send notifications when the host starts and stops flapping, and s = send notifications when scheduled downtime starts and ends. If you specify n (none) as an option, no host notifications will be sent out. If you do not specify any notification options, Nagios will assume that you want notifications to be sent out for all possible states. Example: If you specify d,r in this field, notifications will only be sent out when the host goes DOWN and when it recovers from a DOWN state.
Re: Recovery alert after no warning alert
What version of Nagios Core are you running?
there were a few recent issues regarding this that should be fixed in the maint branch here
https://github.com/NagiosEnterprises/na ... tree/maint
amprantino
I am using 4.4.1 with some fixes from git; downloaded on 20180813 and is probably version 4.4.2 .
So I hit a bug again?
Would you like to install the current main branch and check if the problem is fixed?
Yes please, download and install the full Core 4.4.2 release and install it.
One more thing to do, you will have to stop nagios and delete the retention.dat file so the system will rebuild the counters for the checks / notifications when it starts up.
Then see if it happens again.
amprantino
Sorry, but I cannot delete retention.dat !! It will create chaos in my installation!
Updating the state for specific service, those with problems, will not fix the problem?
Yes, you could edit just the entries in the retention.dat file instead of deleting them all.
That should work as well as they will still have to regenerate the counters.
amprantino
Unfortunately, v.4.4.2 didn't solve the problem :(
Was the host check in a down state when the service was in a down state as well?
Does this issue describe how your system is behaving?
https://github.com/NagiosEnterprises/na ... issues/572
