Thanks for the heads up! We will update/correct our KB article on the topic. Having said that, I believe that restarting MariaDB would reset these settings ONLY if you already have the STRICT_TRANS_TABLES entry in /etc/my.cnf, for example:
sql_mode=NO_ENGINE_SUBSTITUTION,STRICT_TRANS_TABLES
What is the MariaDB's version that you are currently using? Was mariadb "pre-installed/pre-configured" on this server, prior to installing Nagios XI? I don't think we add the line listed above to the my.cnf file...
Anyway, I am glad your issue has been resolved. Let us know if it is OK to close the topic. Thank you!
