How to monitor long running processes?
Siddharth Hegde
I have couple of long running processes in server which runs for days at stretch. Is there a way to get alerts when they stop or exit? How to monitor them in NRPE?
Regards,
Siddarth Hegde
Regards,
Siddarth Hegde
npolovenko
- Support Tech
Re: How to monitor long running processes?
@Siddharth Hegde, Are you looking to monitor processes on a windows server or on a linux server? You can find some examples here:
https://support.nagios.com/kb/article/p ... s-782.html
Siddharth Hegde
npolovenko
- Support Tech
@Siddharth Hegde, You can use the check_procs plugin. Put the following command in the nrpe.cfg file on the Ubuntu server.
And here's the command to run from the Nagios server.command[check_process]=/usr/local/nagios/libexec/check_procs $ARG1$
You can replace httpd with the name of the process you want to monitor. And you can replace my current critical range 2:5 with your own. Meaning that the plugin will return in Critical state if there are 2 to 5 httpd processes running on the Ubuntu server./usr/local/nagios/libexec/check_nrpe -H IP_address -c check_process -a "-a httpd -c 2:5"
Siddharth Hegde
Let us know if we can be of further assistance
Siddharth Hegde
My apologies for replying very late. I have a followup query.
I have a process, process.jar, which is a single process which should be running all the time. I want to monitor this process.
What should I enter in client.cfg in nagios server? What should I put in client nrpe.cfg?
Please let me know if I have to create a new thread for this or can be continued in this thread.
Regards,
Siddarth Hegde
Regards,
Siddarth Hegde
we would need to know what the process line looks like
Can you run the following on the server
ps -ef|grep process.jar-
Siddharth Hegde
I got thisscottwilkerson wrote:we would need to know what the process line looks like
root 98376 98355 0 14:57 pts/0 00:00:00 grep --color=auto process.jar
If this is your only output then there is not a process running called process.jar
Are you sure that is what it is called?
