add column to "Operations Screen"
Is it possible to add "hostgroup" name to the Operations Screen dashboard?
npolovenko
- Support Tech
Re: add column to "Operations Screen"
Hello, @dinush. It's not possible with the Operations Screen. However, you can search for problems in the selected host group with the Operations Center component.
