I have problem with timeout with powershell script. On 90% servers I don't have problem but on some of them I have timeout (Service check timed out after 60.01 seconds).
It's my nsclient.ini
# If you want to fill this file with all avalible options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; Undocumented key
password = xxxx
; Undocumented key
allowed hosts = 127.0.0.1,::1,x.x.x.x
; CACHE ALLOWED HOSTS - If host names (DNS entries) should be cached, improves speed and security somewhat but won't allow you to have dynamic IPs for your Nagios server.
cache allowed hosts = 1
; TIMEOUT - Timeout when reading packets on incoming sockets. If the data has not arrived within this time we will bail out.
timeout = 120
[/settings/NRPE/server]
; Undocumented key
ssl options = no-sslv2,no-sslv3
; ENABLE SSL ENCRYPTION - This option controls if SSL should be enabled.
use ssl = 1
; PORT NUMBER - Port to use for NRPE.
port = 5666
; EXTENDED RESPONSE - Send more then 1 return packet to allow response to go beyond payload size (requires modified client if legacy is true this defaults to false).
extended response = 1
; COMMAND ARGUMENT PROCESSING - This option determines whether or not the we will allow clients to specify arguments to commands that are executed.
allow arguments = true
; COMMAND ALLOW NASTY META CHARS - This option determines whether or not the we will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow nasty characters = true
; ALLOW INSECURE CHIPHERS and ENCRYPTION - Only enable this if you are using legacy check_nrpe client.
insecure = true
; VERIFY MODE - Comma separated list of verification flags to set on the SSL socket. none The server will not send a client certificate request to the client, so the client will not send a certificate. peer The server sends a client certificate request to the client and the certificate returned (if any) is checked. fail-if-no-cert if the client did not return a certificate, the TLS/SSL handshake is immediately terminated. This flag must be used together with peer. peer-cert Alias for peer and fail-if-no-cert. workarounds Various bug workarounds. single Always create a new key when using tmp_dh parameters. client-once Only request a client certificate on the initial TLS/SSL handshake. This flag must be used together with verify-peer
verify mode = none
[/modules]
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NSClientServer = 1
; NRPEServer - A server that listens for incoming NRPE connection and processes incoming requests.
NRPEServer = enabled
; CheckExternalScripts - Execute external scripts
CheckExternalScripts = enabled
; Configure which services has to be in which state
[/settings/system/windows/service mapping]
; A set of options to configure the real time checks
[/settings/system/windows/real-time]
; Add counters to check
[/settings/system/windows/counters]
; Section for system checks and system settings
[/settings/system/windows]
; DEFAULT LENGTH - Used to define the default interval for range buffer checks (ie. CPU).
default buffer length = 1h
; Configure log file properties.
[/settings/log/file]
; MAXIMUM FILE SIZE - When file size reaches this it will be truncated to 50% if set to 0 (default) truncation will be disabled
max size = 0
; Section for configuring the log handling.
[/settings/log]
; LOG LEVEL - Log level to use. Available levels are error,warning,info,debug,trace
level = info
; DATEMASK - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
date format = %Y-%m-%d %H:%M:%S
; FILENAME - The file to write log data to. Set this to none to disable log to file.
file name = ${exe-path}/nsclient.log
[/settings/eventlog/real-time]
; REAL TIME CHECKING - Spawns a background thread which detects issues and reports them back instantly.
enabled = 0
; STARTUP AGE - The initial age to scan when starting NSClient++
startup age = 30m
; LOGS TO CHECK - Comma separated list of logs to check
log = application,system
; DEBUG - Log missed records (useful to detect issues with filters) not useful in production as it is a bit of a resource hog.
debug = 0
; Section for configuring the shared session.
[/settings/shared session]
; ENABLE THE SAHRED SESSION - This is currently not added in 0.4.x
enabled = false
; Section for configuring the crash handler.
[/settings/crash]
; RESTART SERVICE NAME - The url to submit crash reports to
restart target = NSCP
; CRASH ARCHIVE LOCATION - The folder to archive crash dumps in
archive folder = ${shared-path}/crash-dumps
; SUBMISSION URL - The url to submit crash reports to
submit url = https://crash.nsclient.org/post
; RESTART - Submit crash reports to nsclient.org (or your configured submission server)
restart = true
; ARCHIVE CRASHREPORTS - Archive crash reports in the archive folder
archive = true
; SUBMIT CRASHREPORTS - Submit crash reports to nsclient.org (or your configured submission server)
submit = false
; A set of filters to use in real-time mode
[/settings/system/windows/real-time/checks]
; Section for NSClient (NSClientServer.dll) (check_nt) protocol options.
[/settings/NSClient/server]
; PERFORMANCE DATA - Send performance data back to Nagios (set this to 0 to remove all performance data).
performance data = 1
use ssl = 0
; PORT NUMBER - Port to use for check_nt.
port = 12489
; Section for external scripts configuration options (CheckExternalScripts).
[/settings/external scripts]
; COMMAND TIMEOUT - The maximum time in seconds that a command can execute. (if more then this execution will be aborted). NOTICE this only affects external commands not internal ones.
timeout = 120
; Files to be included in the configuration
[/includes]
; Section for the EventLog Checker (CheckEventLog.dll).
[/settings/eventlog]
; BUFFER_SIZE - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
buffer size = 131072
; LOOKUP NAMES - Lookup the names of eventlog files
lookup names = 1
; DEBUG - Log more information when filtering (useful to detect issues with filters) not useful in production as it is a bit of a resource hog.
debug = 0
; A list of scripts available to run from the CheckExternalScripts module. Syntax is: <command>=<script> <arguments>
check_updates=cmd /c echo scripts\Check-Updates.ps1; exit $LastExitCode | powershell.exe -command -
; A list of aliases available.
;An alias is an internal command that has been predefined to provide a single command without arguments. Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all
alias_sched_all = check_tasksched show-all "syntax=${title}: ${exit_code}" "crit=exit_code ne 0"
; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size
alias_file_size = check_files "path=$ARG1$" "crit=size > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${size}" max-dir-depth=10
; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung
alias_process_hung = check_process "filter=is_hung" "crit=count>0"
; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process
alias_process = check_process "process=$ARG1$" "crit=state != 'started'"
; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex
alias_service_ex = check_service "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log
alias_event_log = check_eventlog
; alias_volumes_loose - Alias for alias_volumes_loose. To configure this item add a section called: /settings/external scripts/alias/alias_volumes_loose
alias_volumes_loose = check_drivesize
; alias_volumes - Alias for alias_volumes. To configure this item add a section called: /settings/external scripts/alias/alias_volumes
alias_volumes = check_drivesize
; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk
alias_disk = check_drivesize
; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up
alias_up = check_uptime
; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age
alias_file_age = check_files "path=$ARG1$" "crit=written > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${written}" max-dir-depth=10
; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex
alias_cpu_ex = check_cpu "warn=load > $ARG1$" "crit=load > $ARG2$" time=5m time=1m time=30s
; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped
alias_process_stopped = check_process "process=$ARG1$" "crit=state != 'stopped'"
; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service
alias_service = check_service
; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu
alias_cpu = check_cpu
; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem
alias_mem = check_memory
; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count
alias_process_count = check_process "process=$ARG1$" "warn=count > $ARG2$" "crit=count > $ARG3$"
; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long
alias_sched_long = check_tasksched "filter=status = 'running'" "detail-syntax=${title} (${most_recent_run_time})" "crit=most_recent_run_time < -$ARG1$"
; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task
alias_sched_task = check_tasksched show-all "filter=title eq '$ARG1$'" "detail-syntax=${title} (${exit_code})" "crit=exit_code ne 0"
; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose
alias_disk_loose = check_drivesize
; A list of wrapped scripts (ie. scruts using a template mechanism). The template used will be defined by the extension of the script.
; A list of templates for wrapped scripts.
;%SCRIPT% will be replaced by the actual script an %ARGS% will be replaced by any given arguments.
[/settings/external scripts/wrappings]
; BATCH FILE WRAPPING -
bat = scripts\\%SCRIPT% %ARGS%
; VISUAL BASIC WRAPPING -
vbs = cscript.exe //T:30 //NoLogo scripts\\lib\\wrapper.vbs %SCRIPT% %ARGS%
; POWERSHELL WRAPPING -
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
[/settings/eventlog/real-time/filters]
[/paths]
; Path for shared-path -
shared-path = C:\Program Files\NSClient++
; Path for exe-path -
exe-path = C:\Program Files\NSClient++
; Path for crash-folder -
crash-folder = C:\Program Files\NSClient++
; Path for certificate-path -
certificate-path = ${shared-path}/security
; Path for base-path -
base-path = C:\Program Files\NSClient++
; Path for module-path -
module-path = ${shared-path}/modules
I use nsclient NSCP-0.4.4.23
I set different timeout but on some servers problem is still existing.
Can I add anything else?
BR
Wojtek
