monitoring vmware host after restore of nagiosxi
newdawnccs
recently i have updated to version 5.5.3 on my old nagios server and then took a backup and restored this backup to a new nagios OVA. that part worked perfectly except that I was unable to monitor my vmware hosts. I have followed the instructions from the document Monitoring VMware with Nagios XI with no errors but when i open the vmware monitoring wizard i still see the error "Error: It appears as though you have not installed the VMware SDK or ESX plugins on your Nagios XI server. You must have these components properly installed on your system before using this wizard" I have made sure the wizard file is located in the proper directory. also the vmware hosts that i already had installed from the restore are reading "(Return code of 127 is out of bounds. Check if plugin exists)" any help would be appreciated....thanks
npolovenko
- Support Tech
Re: monitoring vmware host after restore of nagiosxi
Hi, @newdawnccs. I believe I already answered this question today.
https://support.nagios.com/forum/viewto ... =6&t=50277
