Local Password Requirements
I can't believe this isn't present already, but Fusion should have the same Local Password Requirements options that XI has.
Nagios XI 2026R1.5 (8 Servers)
Nagios Fusion 2024R1.0.2
npolovenko
- Support Tech
Re: Local Password Requirements
@TBT, Are you talking about the option for LDAP users to be able to log in with a local password? Which version of Fusion are you using right now?
1. Nope, local passwords in Fusion. The available options within XI can be viewed by navigating to Admin > System settings > Passwords & Accounts: Local Password Requirementsnpolovenko wrote:@TBT, Are you talking about the option for LDAP users to be able to log in with a local password? Which version of Fusion are you using right now?
2. Evaluating Nagios Fusion 4.1.5
While we're on the topic, as Fusion 4.1.5 doesn't have an upgrade path requiring a complete reinstall, is there any way to migrate the account credentials over from Fusion 2014R1.1 rather than recreate?
npolovenko
- Support Tech
@TBT, I confirmed that Fusion doesn't have this functionality and submitted a feature request on your behalf.
According to our update doc, there is a way to upgrade Fusion from 2014R1.1 to the latest version. You'd need to upgrade to the Fusion 4.0.0 first, and then do another upgrade to the Fusion 4.1.5.
https://assets.nagios.com/downloads/nag ... ctions.pdf
Otherwise, we don't have a supported way of migrating the account credentials.
