NagiosXI and Slack integration
NinoBenamy
Post by NinoBenamy »
I have integrated slack notification using the link below
However, i would like to add the $HOSTNOTESURL$ as another field. But it doesnt seem to work
./slack_nagios.pl -field slack_channel=#nagios -field HOSTALIAS="$HOSTNAME$" -field HOSTSTATE="$HOSTSTATE$" -field NOTESURL="$HOSTNOTESURL$"
I am only getting this message from slack. and not getting the notes_url
Host ‘Linux-Test-ninobenamy’ is UP:
SSH OK - OpenSSH_7.4 (protocol 2.0)
Nino
Re: NagiosXI and Slack integration
In order to change what Slack displays you would need to modify the Slack app...
Another way around this would be to pass this into the HOSTOUTPUT field like so
$USER1$/slack_nagios.pl -field slack_channel="#hosts" -field
HOSTOUTPUT="$HOSTOUTPUT$ - URL: $HOSTNOTESURL$" -field NOTIFICATIONTYPE="$NOTIFICATIONTYPE$"
NinoBenamy
Thank you. your suggestion works. :)
NinoBenamy wrote:Thank you. your suggestion works. :)
great!
Locking thread
