Hello to everyone i am newbie to Nagios and i am having a problem for sending email alert. I am using nagios Core 4.4.2 on Ubuntu 16.04. Here are my config files, any help is very apprecitated.
contacts.cfg
define contact {
contact_name nagiosadmin
use generic-contact
alias Nagios Admin
email [email protected]
define contactgroup {
contactgroup_name admins
alias Nagios Administrators
members nagiosadmin
commands.cfg
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mailx -s ""** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /usr/bin/mailx -s ** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
localhost.cfg
define host {
use linux-server
host_name localhost
alias localhost
address 185.48.117.102
I used Postfix,heilroom,mailx, and none of them didnt work.
Thanks in advance
Nagios email alert
jforcier
Re: Nagios email alert
Are the notification commands defined in the generic-contact template that you are currently using? Can you show us the config?define contact {
use generic-contact
alias Nagios Admin
Hmmm i dont know honeslty, here is what i have found in my template cfg
# Generic contact definition template - This is NOT a real contact, just a template!
define contact{
name generic-contact ; The name of this contact template
service_notification_period 24x7 ; service notifications can be sent anytime
host_notification_period 24x7 ; host notifications can be sent anytime
service_notification_options w,u,c,r,f,s ; send notifications for all service states, flapping events, and scheduled downtime events
host_notification_options d,u,r,f,s ; send notifications for all host states, flapping events, and scheduled downtime events
service_notification_commands notify-service-by-email ; send service notifications via email
host_notification_commands notify-host-by-email ; send host notifications via email
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL CONTACT, JUST A TEMPLATE!
# HOST TEMPLATES
# Generic host definition template - This is NOT a real host, just a template!
name generic-host ; The name of this host template
notifications_enabled 1 ; Host notifications are enabled
event_handler_enabled 1 ; Host event handler is enabled
flap_detection_enabled 1 ; Flap detection is enabled
process_perf_data 1 ; Process performance data
retain_status_information 1 ; Retain status information across program restarts
retain_nonstatus_information 1 ; Retain non-status information across program restarts
notification_period 24x7 ; Send host notifications at any time
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL HOST, JUST A TEMPLATE!
name linux-server ; The name of this host template
use generic-host ; This template inherits other values from the generic-host template
check_period 24x7 ; By default, Linux hosts are checked round the clock
check_interval 5 ; Actively check the host every 5 minutes
retry_interval 1 ; Schedule host check retries at 1 minute intervals
max_check_attempts 10 ; Check each Linux host 10 times (max)
check_command check-host-alive ; Default command to check Linux hosts
notification_period workhours ; Linux admins hate to be woken up, so we only notify during the day
; Note that the notification_period variable is being overridden from
; the value that is inherited from the generic-host template!
notification_interval 120 ; Resend notifications every 2 hours
notification_options d,u,r ; Only send notifications for specific host states
contact_groups admins ; Notifications get sent to the admins by default
# Define a template for switches that we can reuse
name generic-switch ; The name of this host template
use generic-host ; Inherit default values from the generic-host template
check_period 24x7 ; By default, switches are monitored round the clock
check_interval 5 ; Switches are checked every 5 minutes
max_check_attempts 10 ; Check each switch 10 times (max)
check_command check-host-alive ; Default command to check if routers are "alive"
notification_period 24x7 ; Send notifications at any time
notification_interval 30 ; Resend notifications every 30 minutes
notification_options d,r ; Only send notifications for specific host states
register 0 ; DONT REGISTER THIS - ITS JUST A TEMPLATE
# SERVICE TEMPLATES
# Generic service definition template - This is NOT a real service, just a template!
name generic-service ; The 'name' of this service template
active_checks_enabled 1 ; Active service checks are enabled
passive_checks_enabled 1 ; Passive service checks are enabled/accepted
parallelize_check 1 ; Active service checks should be parallelized (disabling this can lead to major performance problems)
obsess_over_service 1 ; We should obsess over this service (if necessary)
check_freshness 0 ; Default is to NOT check service 'freshness'
notifications_enabled 1 ; Service notifications are enabled
event_handler_enabled 1 ; Service event handler is enabled
is_volatile 0 ; The service is not volatile
check_period 24x7 ; The service can be checked at any time of the day
max_check_attempts 3 ; Re-check the service up to 3 times in order to determine its final (hard) state
normal_check_interval 10 ; Check the service every 10 minutes under normal conditions
retry_check_interval 2 ; Re-check the service every two minutes until a hard state can be determined
contact_groups admins ; Notifications get sent out to everyone in the 'admins' group
notification_options w,u,c,r ; Send notifications about warning, unknown, critical, and recovery events
notification_interval 60 ; Re-notify about service problems every hour
notification_period 24x7 ; Notifications can be sent out at any time
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
# Local service definition template - This is NOT a real service, just a template!
name local-service ; The name of this service template
use generic-service ; Inherit default values from the generic-service definition
max_check_attempts 4 ; Re-check the service up to 4 times in order to determine its final (hard) state
normal_check_interval 5 ; Check the service every 5 minutes under normal conditions
retry_check_interval 1 ; Re-check the service every minute until a hard state can be determined
define contact{
# HOST TEMPLATES
# SERVICE TEMPLATES
What is the output of the following command?
Have you tried sending an email from the command line?
Try:
Check your email to see if you got it. If not, review the mail.log as it is possible that your email got bounced.
which mailTry:
echo "Test Email" | /usr/bin/mailx -s "Test Subject" [email protected]Code: Select all
tail -50 /var/log/mail.logBe sure to check out our Knowledgebase for helpful articles and solutions!
amprantino
Try sendEmail.pl from here: http://caspian.dotconf.net/menu/Software/SendEmail/
Any update @Dzonii? Have you tried sending an email from the command line?
Thank you so much guys @Imiltchev , sendmail solved my issues, but know i got another challenge. When i install the sendmail my Postfix is down, and a i need to find way to activate them both.
