Hi Support
I am running NagiosXI 5.4.0. I am facing a problem with configuring NagiosXI to forward SNMP TRAP event status Normal to upstream monitoring host. Can you please advise?
I have configured NagiosXI to receive SNMP Traps. Received traps are logged in /var/log/snmptt/snmptt.log successfully.
When NagiosXI recieve SNMP TRAP event status with Critical, Major, Minor, it will generate SNMP trap for upstream monitoring host and these are logged in /usr/local/nagiosxi/var/eventman.log
However when Nagios XI recieve SNMP TRAP event status Normal, i see the event gets processed in snmptt.log but don't see it pass on to eventman.log
snmptt.debug
Translated to northboundKeepALiveTrap
EXEC command:/usr/local/bin/snmptraphandling.py "10.X.X.X" "SNMP Traps" "Normal" "1537372896" "" "Host:usgst.abc.com; SvcDesc: The keep-a-live trap."
Processing file: #snmptt-trap-1537372899610270
Reading trap. Current time: Thu Sep 20 00:01:41 2018
I have already tried adding the forward default X.X.X.X:162 to /etc/snmp/snmptrapd.conf file
[root@COMMON-NAGIOS-01 snmptt]# cat /etc/snmp/snmptrapd.conf
disableAuthorization yes
perl do "/usr/sbin/snmptthandler-embedded";
forward default 10.X.X.X:162
Nagiox XI does not send trap for Normal "Status Events"
nfv_nagios
Re: Nagiox XI does not send trap for Normal "Status Events"
If you want to forward the traps the Nagios server receives to another server and also receive the trap on the XI server you need to enable the net type:
Edit this file
It would have to be setup like this example. Replace xxx.xxx.xxx.xxx with the IP address of the system you want to forward the traps to.
Save the file and restart the snmptrapd daemon by running
Can you post the entry from the /usr/local/nagiosxi/var/eventman.log file so we can view it?
Can you post the Trap settings for the Normal status and the Critical status from the /etc/snmp/snmptt.conf file?
Edit this file
/etc/snmp/snmptrapd.conf It would have to be setup like this example. Replace xxx.xxx.xxx.xxx with the IP address of the system you want to forward the traps to.
traphandle default /usr/sbin/snmptthandler
authCommunity log,net public
forward default xxx.xxx.xxx.xxx publicCode: Select all
service snmptrapd restartCan you post the entry from the /usr/local/nagiosxi/var/eventman.log file so we can view it?
