I have nagios server and nrpe servers in the same subnet. Can they communicate with each other as they are in the same network? Or should I open port 5666 in all of nrpe servers?
Regards,
Siddarth Hegde
Nagios Port information
Re: Nagios Port information
port 5666 needs to be open on all NRPE servers AND you needs to add the nagios servers IP address to the allowed_hosts field in the nrpe.cfg and restart nrpe
Siddharth Hegde
Can i open port only for select IPs as i don't wan't to expose it?
Regards,
Siddarth Hegde
Regards,
Siddarth Hegde
Yes the iptables rule would be something like this on the remote machines
iptables -I INPUT -p tcp -s xxx.xxx.xxx.xxx --dport 5666 -j ACCEPT-
Siddharth Hegde
Thank You
No problem!Siddharth Hegde wrote:Thank You
