Nagios XI 5.5.2 - service depencies issue...
vishfx
Post by vishfx »
Hi Team,
When I apply the below service dependency, Apply Changes goes through, however nagios core does not seem to come up.
# Servicedependencies configuration file
# Created by: Nagios CCM 2.7.0
# Date:       2018-09-21 02:46:20
# Version:    Nagios Core 4.x
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define servicedependency {
    # config_name                    MDC_RR2C_PCFDEV_p-metric_svc_dependency
    dependent_host_name              p-metrics-71415ddea442ea30c867
    dependent_service_description    jmx-firehose-nozzle/17ea07c5-fdc3-4e27-a45c-69a783397913/disk_ephemeral_inode_percent,jmx-firehose-nozzle/17ea07c5-fdc3-4e27-a45c-69a783397913/disk_ephemeral_percent,jmx-firehose-nozzle/17ea07c5-fdc3-4e27-a45c-69a783397913/disk_persistent_inode_percent,jmx-firehose-nozzle/17ea07c5-fdc3-4e27-a45c-69a783397913/disk_persistent_percent
    host_name                        cf-d9e5d142a1824d66533f
    service_description              router/0003dc5d-c6ab-4a6b-a6b9-8a0390ea1436/system_healthy
    inherits_parent                  1
    execution_failure_criteria       w,u,c,p,
    notification_failure_criteria    w,u,c,p,
    dependency_period                24x7
# END OF FILE
Neither do I see any errors in nagios.log
-bash-4.2$ tail -f /usr/local/nagios/var/nagios.log
[1537516407] ndomod registered for external command data'
[1537516407] ndomod registered for aggregated status data'
[1537516407] ndomod registered for retention data'
[1537516407] ndomod registered for contact data'
[1537516407] ndomod registered for contact notification data'
[1537516407] ndomod registered for acknowledgement data'
[1537516407] ndomod registered for state change data'
[1537516407] ndomod registered for contact status data'
[1537516407] ndomod registered for adaptive contact data'
[1537516407] Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
Kindly assist.
Regards,
Vish.
Re: Nagios XI 5.5.2 - service depencies issue...
Do you see any config errors when you write configs and verify files from the GUI?
CCM > Config File Management > Write Configs > Verify Files
Run the following commands and show the output in code wraps:
su - nagios
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
service nagios status
chage nagios -l
vishfx
Post by vishfx »
This ticket can be closed.
I no longer encounter this issue.
Thanks for the support.
Regards,
Vish.
