How preserve changes to the template after upgrade.
dclsystems
Post by dclsystems »
How to preserve changes to the host, service passive check template freshness settings between NagiosXI upgrades?
Rafal
Re: How preserve changes to the template after upgrade.
Nagios shouldn't be changing these, is there a specific template you saw changed?
One way to for sure do this would be to Apply Configuration just before the upgrade, then you can roll back the configuration to the one you made just before the upgrade.
