Escalations no longer notifying on return to "OK" state.
HawkFan
Post by HawkFan »
System Overview:
CentOS 6.9
64 bit
Virtualized system
Using SSL
Nagios XI 5.5.4 (Problem existed in 5.5.3 and possibly earlier.)
We use service and host escalations for all notifications, and we no longer receive notifications when the status changes back to "OK". Warning and critical notifications are still received. This is impacting multiple services we monitor.
This all previously worked fine for years. I believe one of the last few upgrades may have changed something to cause this problem.
Re: Escalations no longer notifying on return to "OK" state.
Can you show us a sample escalation? We will try to recreate the issue in-house. Thank you!
HawkFan
Post by HawkFan »
Here you go, thanks. The monitor is service related, but I'll post both host and service escalation config.
define hostescalation {
# config_name Email Hawk Fan
hostgroup_name Hawk
contacts HawkFan
first_notification 1
last_notification 0
notification_interval 5
escalation_period 24x7
escalation_options u,r,d,
define serviceescalation {
# config_name Email HawkFan
hostgroup_name Hawk
service_description *
contacts HawkFan
last_notification 0
escalation_options w,u,c,r,
HawkFan
Post by HawkFan »
To add additional info:
Host Escalation notifications work correctly between states. (Critical > OK)
Service Escalations notifications work correctly for warning and critical, but an OK status is never sent. The problem is isolated to "OK" service escalation notifications. All services appear to be impacted.
We haven't been able to recreate the issue in-house. I tried a similar (very simple) service escalation in Nagios XI 5.5.4.
    # config_name            test
    hostgroup_name           linux-servers
    contacts                 ludmil
    last_notification        0
define hostgroup {
    alias             Linux Servers
    members           localhost
After a couple of my services recovered from a Critical state, recovery (OK) notifications were sent.
There must be some other issues on your system that caused the issue. I believe this needs to be moved to our ticketing system for faster resolution. Can you open a new ticket via our support center here?
https://support.nagios.com/tickets/
