hello; am faced with challenge to monitor "Oracle Solaris 10 8/11 s10s_u10wos_17b SPARC".
i have managed to install the nagios plugins.
but when I try to install nrpe-2.12, I am hitting a snag, where I get errors as below;
# make
cd ./src/; make ; cd ..
gcc -g -O2 -I/usr/sfw//include/openssl -I/usr/sfw//include -DHAVE_CONFIG_H -o nrpe nrpe.c utils.c -L/usr/sfw/lib/ -lssl -lcrypto -lnsl -lsocket
nrpe.c:616:3: #else without #if
nrpe.c:617:4: invalid preprocessing directive #log_facility
nrpe.c:618:3: #else without #if
nrpe.c:619:4: invalid preprocessing directive #log_facility
nrpe.c: In function `get_log_facility':
nrpe.c:621: error: syntax error before '.' token
nrpe.c: At top level:
nrpe.c:648: error: syntax error before "return"
*** Error code 1
make: Fatal error: Command failed for target `nrpe'
Current working directory /tmp/nrpe-2.12/src
*** Error code 1
make: Fatal error: Command failed for target `all'
checked the path;
# which make
/usr/ccs/bin/make
previously I have successfully installed on "Solaris 10 11/06 s10s_u3wos_10 SPARC"
what could I be missing here?
thanks
Oracle Solaris 10 8/11 s10s_u10wos_17b SPARC monitoring
Re: Oracle Solaris 10 8/11 s10s_u10wos_17b SPARC monitoring
Before running make, try this:
replace
with
vi src/nrpe.cCode: Select all
else if(!strcmp(varvalue,”authpriv”))
log_facility=LOG_AUTHPRIV;
else if(!strcmp(varvalue,”ftp”))
log_facility=LOG_FTP;Code: Select all
log_facility=LOG_AUTH;
log_facility=LOG_DAEMON;
