UDP port for monitor
Vigneshwar.A
Post by Vigneshwar.A »
Hello Team,
I need to monitor UDP port 1162 in nagios, so for that am using the below script,
https://exchange.nagios.org/directory/P ... rt/details
when i tried in nagios server putty session its giving an output stating that its working fine but when i configured the same in GUI its giving critical, so kindly help us to resolve the issue. PFA info
Putty Output:
[root@xxxxx libexec]# /usr/local/nagios/libexec/check_udp_port -H xxxxx -p 1162 -s "health-trap"
OK: health-trap listening on port 1162: 1162/udp open|filtered health-trap
Nagios Command:
$USER1$/check_udp_port -H $HOSTADDRESS$ -p $ARG1$ -s $ARG2$
Nagios Version: 5.4.12
OS: Red Hat Enterprise Linux Server release 7.3
npolovenko
Re: UDP port for monitor
Post by npolovenko »
Hello, @Vigneshwar.A. You need to add the following line to the /etc/sudoers:
NAGIOSXI ALL = NOPASSWD:/usr/local/nagios/libexec/check_udp_port *
And the command definition should be:
sudo $USER1$/check_udp_port -H $HOSTNAME$ -p $ARG1$ -s $ARG2$
Vigneshwar.A
As per your concern i have made entries in /etc/sudoers file and command has been created.
When we checked in nagios CCM back-end the UDP Port service by giving run check command its working but in front end its still showing critical alert. PFB SS
npolovenko
@Vigneshwar.A, What are the permissions on the plugin?
ls -l /usr/local/nagios/libexec/check_udp_port
Please sign in to the console as the nagios user, run the plugin and show me the output.
su - nagios
/usr/local/nagios/etc/libexec/check_udp_port -H replace_with_ip_address -p 1162 -s "health-trap"
Vigneshwar.A
Hi Npolovenko,
check_udp_port plugin has 777 permission to execute. PFB output
[root@xxxxxxxxx libexec]# ls -ltr|grep -i check_udp_port
-rwxrwxrwx. 1 root nagios 1615 Sep 25 12:27 check_udp_port
Nagios user output:
[nagios@xxxxxxxx ~]$ ls -ltr /usr/local/nagios/libexec/check_udp_port
-rwxrwxrwx. 1 root nagios 1615 Sep 25 12:27 /usr/local/nagios/libexec/check_udp_port
[nagios@xxxxxxxx libexec]$ ./check_udp_port -H xxxxxxxxxxx -p 1162 -s "health-trap"
You requested a scan type which requires root privileges.
QUITTING!
CRITICAL:
[nagios@xxxxxxx libexec]$
npolovenko
@Vigneshwar.A, What about running the command with sudo as the nagios user?
[nagios@xxxxxxxx libexec]$ sudo /usr/local/nagios/check_udp_port -H xxxxxxxxxxx -p 1162 -s "health-trap"
Vigneshwar.A
PFB output for the command.
[nagios@XXXXX ~]$ sudo /usr/local/nagios/libexec/check_udp_port -H XXXXXX -p 1162 -s "health-trap"
[nagios@XXXXX ~]$
It seems like now you can run the plugin as nagios user, so the check should also work for you in the GUI. Let us know if your issue has been resolved.
Vigneshwar.A
lmiltchev wrote:It seems like now you can run the plugin as nagios user, so the check should also work for you in the GUI. Let us know if your issue has been resolved.
Still am facing same issue, backend CCM UDP Port service is working but in frontend GUI still its showing CRITICAL ;)
PFA SS
Have you applied configuration after making the changes to your configs, e.g. adding sudo to the "check_udp_port" command? Try going to the CCM > Tools > Config File Management > Delete Files > Write Configs > Verify Files > Apply Configuration (in this exact order).
Another reason for the issue could be multiple nagios processes running on this machine. Perhaps, there is an old nagios process running that is "stuck" and it's still reporting "Critical".
To check for multiple instances of nagios, run:
ps -ef | head -1 && ps -ef | grep bin/nagios
To kill the process run:
service nagios stop
killall nagios
service nagios start
