Hi! Is there a way to change the manage template for a list of host.
I've created some hosts, but the manage template I've used is wrong.
Checked in the bulk change options but no luck.
Bulk change multiple hosts for their manage template
jforcier
Re: Bulk change multiple hosts for their manage template
The bulk modification tool in the core config manager has an option to change templates.
Thanks. Finally found it. Would be nice to be able to have a view of all the host associated with a specific template.
If there's one... Still looking to find it.
glad you found it, unfortunately we do not have a tool/report to see which host is using what template.typer100 wrote:Thanks. Finally found it. Would be nice to be able to have a view of all the host associated with a specific template.
Locking thread
