Invalid command line: unrecognised option '-a' ERROR for all NRPE-based CPU monitoring after 5.5.4 upgrade !
Command:
-a show-all -a 'warn=load>85' 'crit=load>95' show-all
Please help (profile attached)
Invalid command line: unrecognised option '-a' after 5.5.4
Reason: Profile removed and shared with the other Techs
Re: Invalid command line: unrecognised option '-a' after 5.5
On the phone with the customer and found that some of the Service Checks had the -a argument for the NRPE checks specified twice. Removed then and the checks started to function.
Thank you, did just that and everything worked (not sure how this happened in first place - almost as if 5.5.4 upgrade created these entries)tgriep wrote:On the phone with the customer and found that some of the Service Checks had the -a argument for the NRPE checks specified twice. Removed then and the checks started to function.
Glad it is sorted.dlukinski wrote:Thank you, did just that and everything worked (not sure how this happened in first place - almost as if 5.5.4 upgrade created these entries)tgriep wrote:On the phone with the customer and found that some of the Service Checks had the -a argument for the NRPE checks specified twice. Removed then and the checks started to function.
Locking thread.
