showmount: Program not registered
shamrozkadiwal
Post by shamrozkadiwal »
I have nagios core 3.3.1 installed and setup NFS monitoring which is throwing this alert "showmount: RPC: Program not registered ". I am not quite sure what to check. However, I did google it and all pointed to restart nfs, nfslock, and rpc service which i did and didn't resolve the issue. Client is running on the Centos 5. Please let me know if anybody has any suggestion.
Re: showmount: Program not registered
Post by mcapra »
Can you share the full Nagios service definition associated with the "NFS" service on host "awhu013a"?
Can you also share copies of any scripts/plugins supporting the check_command parameter under the "NFS" service definition?
This sounds like some sort of systemd/initd problem related to the nfs system service on this machine. Not exactly a Nagios Core related problem.
Any updates @shamrozkadiwal?
shamrozkadiwal
Please bear with me and I will shortly post the service and host definition associated with the NFS. However, my other servers are reporting the NFS just fine. This is the only one which is throwing UNKNOWN error.
Whenever you are ready.
shamrozkadiwal
Command
# Check if the NFS server is running (version 2 and version 3)
        command_name check-nfs
        command_line $USER1$/check_rpc -H $HOSTADDRESS$ -C nfs -c2,3
Hostgroup
define hostgroup{
        hostgroup_name  linux-vm-servers
        alias           Virtual Linux Servers
define hostgroup{
        hostgroup_name  linux-web-servers
        alias           Linux Web Servers
Host
        host_name       awhu013a
        hostgroups      linux-vm-servers,linux-web-servers
        alias           awhu013a
        address         X.X.X.X
        use             generic-web
        notification_period            work-hours
Service
        use                     generic-24x7-email
        servicegroups           data-services
        service_description     NFS
        check_command           check_nfs
        normal_check_interval   360
I got this
I got this when I ran the below command from the nagios server.
shamroz@nagios /etc/nagios/services $ sudo /usr/lib/nagios/plugins/check_rpc -H X.X.X.X -C nfs -c2,3
CRITICAL: RPC program nfs version 2 version 3 udp is not running
Your command is defined as "check-nfs":
but your service uses a command called "check_nfs"...
shamrozkadiwal
Sorry lmiltchev, I overlooked the command.cfg. However, I have found another NFS command as
        command_name check_nfs
        command_line $USER1$/check_nfs.pl -H $HOSTADDRESS$
and when I tried to run this command from the nagios server to the host, I got this
shkadi@nagios /etc/nagios/commands $ sudo /usr/lib/nagios/plugins/check_nfs.pl -H X.X.X.X
Where did you get this plugin? Does it have any instructions on dependencies?
shamrozkadiwal
I got the script from the internet very long time ago. However, script works fine with other hosts.
