Quick Email Alert Notifications
Hi Team,
I want to know what settings I have to use in order get to quick email alerts if hosts gets down and service gets critical or warning. Or if it gets socket timeout etc ? Kindly mention the settings here.
I am using nagios core Version 4.4.2
Regards,
rlinux57
Regards,
rlinux57
Re: Quick Email Alert Notifications
The fastest alerts would be up to 1 minute, if you set the following in the object definitions
check_interval 1
max_check_attempts 1
retry_interval 1Re: Quick Email Alert Notifications
I have set:
max_attempts 3 (for host)
max_attempts 5 (for services)
Actually when my node goes down, I got"SERVICE ALERT" and "Warning: Return code of 255 for check of service" of some services. Moreover, I didn't get any "HOST ALERT" warning or critical. I don't know why ?
We would need to see all the relevant configurations for the hosts and included templates as well as the associated contact definitions and defined commands in order to evaluate why there were no host notifications.
I have sent detail in private message to you and hide all sensitive information.
received, waiting on a few additional details. We can continue via PM
I setup all the configs you sent me and there were no services defined.
That said, I did re-read your previous message.
Are you saying you are getting an email notification or just an alert in the UI/Log? Because getting alerted in the UI/Log is standard behavior, only the email notification would be suppressed if the host was down.rlinux57 wrote:Actually when my node goes down, I got"SERVICE ALERT" and "Warning: Return code of 255 for check of service" of some services. Moreover, I didn't get any "HOST ALERT" warning or critical. I don't know why ?
Service has defined in that file, I mean to say HOST DOWN Alert and Notification has not generated, When Host gets down.
I am seeing both the host down alerts and the notifications in my /usr/local/nagios/var/nagios.logrlinux57 wrote:Service has defined in that file, I mean to say HOST DOWN Alert and Notification has not generated, When Host gets down.
[1538159800] HOST ALERT: linux-01;DOWN;SOFT;1;check_icmp: Failed to resolve IP-ADDRESS
[1538159815] HOST ALERT: linux-02;DOWN;SOFT;1;check_icmp: Failed to resolve IP-ADDRESS
[1538159836] HOST ALERT: linux-03;DOWN;SOFT;1;check_icmp: Failed to resolve IP-ADDRESS
[1538159924] HOST NOTIFICATION: nagiosadmin;linux-01;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538159924] HOST NOTIFICATION: john;linux-01;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538159924] HOST ALERT: linux-01;DOWN;HARD;3;check_icmp: Failed to resolve IP-ADDRESS
[1538159932] HOST NOTIFICATION: nagiosadmin;linux-02;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538159932] HOST NOTIFICATION: john;linux-02;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538159932] HOST ALERT: linux-02;DOWN;HARD;3;check_icmp: Failed to resolve IP-ADDRESS
[1538159954] HOST NOTIFICATION: nagiosadmin;linux-03;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538159954] HOST NOTIFICATION: john;linux-03;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538159954] HOST ALERT: linux-03;DOWN;HARD;3;check_icmp: Failed to resolve IP-ADDRESS
[1538160104] HOST NOTIFICATION: nagiosadmin;linux-01;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538160104] HOST NOTIFICATION: john;linux-01;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538160112] HOST NOTIFICATION: nagiosadmin;linux-02;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538160112] HOST NOTIFICATION: john;linux-02;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538160134] HOST NOTIFICATION: nagiosadmin;linux-03;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538160139] HOST NOTIFICATION: john;linux-03;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538160284] HOST NOTIFICATION: nagiosadmin;linux-01;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESS
[1538160284] HOST NOTIFICATION: john;linux-01;DOWN;notify-host-by-email;check_icmp: Failed to resolve IP-ADDRESSCode: Select all
[1538164055] SERVICE ALERT: linux-01;Memory - Usage;WARNING;HARD;1;(No output on stdout) stderr: Could not resolve hostname IP-ADDRESS: Name or service not known
[1538164072] SERVICE ALERT: linux-02;Memory - Usage;WARNING;HARD;1;(No output on stdout) stderr: Could not resolve hostname IP-ADDRESS: Name or service not known
[1538164087] SERVICE ALERT: linux-03;Memory - Usage;WARNING;HARD;1;(No output on stdout) stderr: Could not resolve hostname IP-ADDRESS: Name or service not known
Then What's missing ?
