Windows Service notification issues
LS18
Post by LS18 »
Hi there,
Firstly let me apologize if this is a simple mistake, I am brand new to using Linux/Nagios! So far I have everything configured and working in regards to monitoring Windows servers with the exception of notifications for SERVICESTATE alerts for things like W3SVC etc.
The issue I am having is that despite using the same generic-service template for my services, anything I attempt to monitor and get alerts from that uses SERVICESTATE doesn't work correctly.
I know the email works as if I send custom service notifications they fire off, as they do automatically for host or process alerts (PROCSTATE for Explorer.exe etc). For services though I seem to get a single soft alert initially then nothing else as per below:
The attempts register in the web gui as hitting 3/3 but there aren't any notifications sent at this point.
I believe all the config of my definitions and templates are correct:
define contact {
    name                                   generic-contact
    service_notification_period            24x7
    host_notification_period               24x7
    service_notification_options           w,u,c,r,f,s
    host_notification_options              d,u,r,f,s
    service_notification_commands          notify-service-by-email
    host_notification_commands             notify-host-by-email
    register                               0
name 			generic-service
active_checks_enabled	1
passive_checks_enabled	1
parallelize_check            1
obsess_over_service          1
check freshness              0
notifications_enabled        1
event_handler_enabled        1
flap_detection_enabled       1
process_perf_data            1
retain_status_information    1
retain nonstatus information 1
process_perf_data	1
retain_nonstatus_information	1
is volatile	0
check_period	24x7
max_check_attempts	3
check interval	10
retry_interval	2
contact_groups	admins
notification interval	60
register	0
  use                 generic-service
  host_name           IT01199
  service_description W3SVC
  check command       check_nt!SERVICESTATE!-d SHOWALL -I W3SVC
command_name 	check_nt
command_line 	$USER1$/check_nt -H $HOSTADDRESS$ -p 12989 -s passwordhere -v $ARG1$ $ARG2$
and as mentioned when these are used elsewhere like on a PROCSTATE/CPULOAD/USEDDISKSPACE it works fine.
Nagios version is 4.4.1 and using NSclient++ 0.5.2.35 for the Windows side.
Any help is appreciated!
LS
Re: Windows Service notification issues
You have to add a contact to your host/service definition, such as
  use                 generic-service
  host_name           IT01199
  contacts                 nagiosadmin
LS18
Post by LS18 »
Hi Scott,
Thank you for your reply.
I have added the contact field into the service definition but it still doesn't seem to be firing notifications. Is there anything else I could be missing?
I'm a bit confused as to how only SERVICESTATE check_nt commands seem to be the ones effected by this behavior!
Cheers,
LS
LS18 wrote:I have added the contact field into the service definition but it still doesn't seem to be firing notifications. Is there anything else I could be missing?
They would not fire until a service returns to a OK state and then goes down while you have contacts added
LS18
Post by LS18 »
Hi Scott,
I've replicated this behavior and the notifications still wont fire even after the services have been returned to an OK state and then downed again.
I've been checking in the objects.cache as well just be be certain that the updates to the definitions are applying etc. but still no luck.
Any other ideas where I may have gone wrong potentially?
Luke
Can you share the contact configuration for the contact that is assigned to the service?
LS18
Post by LS18 »
Hi Scott,
Of course, please see below:
define contact {
  contact_name   nagiosadmin
  use            generic-contact
  alias          Nagios Admin
  email          [email protected]
define contactgroup {
  contactgroup_name admins
  alias             Nagios Administrators
  members           nagiosadmin
define contact {
    host_notification_period         240
    bost_notification_options        d,u,r,f,s
    register                         0
LS
This all looks correct as long as you have a timeperiod defined as 240
Do the logs show the notifications for the services sending now that you added the contact to the services?
LS18
Post by LS18 »
Sorry not sure why that one is listed as 240, both are listed as:
In the actual template.cfg. I still don't get any notifications sent out though with or without the contacts specifically added to the service as you suggest (I've got one setup using this and another without just to test). All I see in the logs is a single alert:
but then that is it, I don't receive an email for this being down once it turns to a hard 3/3 or if I start it again and it recovers. I've gone over this again and again but I just can't see what I have missed!
LS
And the host is UP?
