Testing the XI 5.5.4 options for Local Password Requirements & Password Complexity. If these system settings are enabled or modified after a User has set their password and password doesn't meet set requirement, there isn't a prompt to change password at next login.
I assume this is the intended behavior, but shouldn't the new settings be enforced upon next login?
Enforcing Local Password Requirements & Password Complexity
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Re: Enforcing Local Password Requirements & Password Complex
Yes, it is intended behavior. You could go to the "Edit User" page, and force the password change at the next login by selecting the appropriate check-box, and clicking on "Update User". You could also turn on the password expiration (Maximum Password Age) to enforce password change after a specified period of time.
