we would like to start monitoring LXD containers from the Linux host without having an agent in the container itself.
Can you help with some recommendations?
Details of our implementation:
CentOS Linux release 7.4.1708 (Core)
Manual Install of Nagios XI
No special configurations on our system, ie; is Gnome installed
We are not using a proxy
We are using Nagios XI 5.4.13.
Thank you.
Issue with LXD monitoring
Re: Issue with LXD monitoring
It appears as though you can send curl requests to the Unix socket and get JSON back:
More info:
https://gist.github.com/jaytaylor/56a99 ... be64396b03
https://lxd.readthedocs.io/en/latest/
That's really all this check_lxd plugin I found is doing, communicating with the Unix socket and returning some sort of interpreted markup (in this case YAML):
https://github.com/alex-left/check-lxd/ ... eck_lxd.py
Very similar to Docker in this case; A socket connection that returns well formatted responses.
More info on using custom plugins with Nagios XI:
#~ curl --unix-socket /var/lib/lxd/unix.socket lxd/1.0/containers/c1/state | jq .metadata
"status": "Running",
"status_code": 103,
"disk": {
"root": {
"usage": 9805824
"memory": {
"usage": 111071232,
"usage_peak": 234029056,
"swap_usage": 0,
"swap_usage_peak": 0
"network": {
"eth0": {
"addresses": [
"family": "inet",
"address": "10.204.119.69",
"netmask": "24",
"scope": "global"
"family": "inet6",
"address": "2001:470:b368:4242:216:3eff:fef4:db69",
"netmask": "64",
"scope": "global"
"family": "inet6",
"address": "fe80::216:3eff:fef4:db69",
"netmask": "64",
"scope": "link"
"counters": {
"bytes_received": 57945,
"bytes_sent": 4876,
"packets_received": 417,
"packets_sent": 38
"hwaddr": "00:16:3e:f4:db:69",
"host_name": "vethSJ6ABH",
"mtu": 1500,
"state": "up",
"type": "broadcast"
"lo": {
"addresses": [
"family": "inet",
"address": "127.0.0.1",
"netmask": "8",
"scope": "local"
"family": "inet6",
"address": "::1",
"netmask": "128",
"scope": "local"
"counters": {
"bytes_received": 0,
"bytes_sent": 0,
"packets_received": 0,
"packets_sent": 0
"hwaddr": "",
"host_name": "",
"mtu": 65536,
"state": "up",
"type": "loopback"
"pid": 22156,
"processes": 29,
"cpu": {
"usage": 6312866518
Thanks @mcapra!
