Does anyone have documentation/instructions on setting up SMS FoxBoxG20 and configuring it to have NagiosXi send notifications through it?
The Nagios Wiki does not have the article "http://wiki.nagios.org/index.php/ACME_SYSTEMS_SMSFoxBox" any more which it also refers to a .sh file (sendSMS.sh) which worked with Nagios on sending it's SMS messages and that file path is not even valid). It was the closest I've seen in setting up FoxBoxG20 with Nagios.
FoxBoxG20 Setup
Re: FoxBoxG20 Setup
I found instructions with scripts online! So far things seem to be working. I'm in the process of configuring it, so Nagios passes the arguments to FoxBox.
I'm using the Core Config Manager, as I am using NagiosXi to make the new "Commands".
Re: FoxBoxG20 Setup
Thank you for posting the documentation you found. Let us know how it works out for you.
