If I run the check on the command line it runs just fine, or if I go into the check in CCM and issue the "Run Check Command" from the UI, it also works. But in the standard check, it times out every single time.
The check in question is "check_snmp_storage.pl" with a timeout of 30 seconds defined in the command.
As an example:
[nagios@server01 ~]$ /usr/local/nagios/libexec/check_snmp_storage.pl -H intranet.domain.com -C REDACTED --v2c -m ^C: -w 80 -c 90 -f -t 30
C:\ Label: Serial Number b683054e: 27%used(78183MB/285466MB) (<80%) : OK | 'C:\_Label:__Serial_Number_b683054e'=78183MB;228373;256919;0;285466Any suggestions on where to look would be greatly appreciated.
Thank you,
