I have 2 plugins check_snmp and check_cisco_int which separately given output of port but i want to combine there output as one.
how can i combine this 2 check commands output as one.
printing more than one plugin output as one
bhaskarbabar
Re: printing more than one plugin output as one
The check_multi plugin is a good option:
https://exchange.nagios.org/directory/P ... ti/details
Feel free to ask questions if something about the plugin's usage is unclear from the documentation.
The only other options would be to write a wrapper script that executes each of them and then you would have to build your own login into the script for triggering any warning or critical values
