Nagios DB
bashar.abed
Nagios DB
Post by bashar.abed »
we have Nagios XI Version 5.4.13 VM machine,we have this issue
DB admins found in his database audit many tried to login by nagios ( IP 10.x.x.10).
please check why such that occurred.
repeated 1 time per min.
Network error code 0x2746 occurred while establishing a connection; the connection has been closed. This may have been caused by client or server login timeout expiration. Time spent during login: total 0 ms, enqueued 0 ms, network writes 0 ms, network reads 0 ms, establishing SSL 0 ms, network reads during SSL 0 ms, network writes during SSL 0 ms, secure calls during SSL 0 ms, enqueued during SSL 0 ms, negotiating SSPI 0 ms, network reads during SSPI 0 ms, network writes during SSPI 0 ms, secure calls during SSPI 0 ms, enqueued during SSPI 0 ms, validating login 0 ms, including user-defined login processing 0 ms. [CLIENT: 10.x.x.10]
what is problem and how can solve it
Re: Nagios DB
There are several cron jobs that run every minute that make new DB connections.
bashar.abed
Re: Nagios DB
i checked the cron job from Nagios Server it is ok and no error
benjaminsmith
Re: Nagios DB
Post by benjaminsmith »
HI,
What is the status of your Nagios XI system right now? Are you able to login?
An overview of Nagios Xi cron jobs on our knowledgebase:
https://support.nagios.com/kb/article/n ... bs-60.html
