Is Nagios support HDP clusters?
kudumha
Post by kudumha »
Hi Masters,
We are planning to implement Nagios as a complete alerting system for HDP cluster. But i heard from couple of forums that HDP clusters from version 2.3x are not supported by Hortonworks. So i just want tocheck with Nagios whether Nagios can support HDP clusters if we implement the alerting sytem instead of using AMS (Ambari Metric System)?
Harsha.
Re: Is Nagios support HDP clusters?
There is a plugin on the Nagios Exchange that may do the job for you - https://exchange.nagios.org/directory/P ... 29/details.
Let us know if this helped.
