It seems that the webinject page is the old 1.41 version but care and feeding of webinject is in CPAN/git now.
https://www.webinject.org/
https://github.com/sni/Webinject
https://metacpan.org/pod/Webinject
Should it be updated from CPAN? I did a yum list perl-webinject and got nothing.
I'm trying to log into web forms, authenticate, and then verify strings but the login alsways seems to fail. I've used numerous plugins from exchange, a script I wrote and finally webinject, which also fails to authenticate. I've also tried multiple different pages to test on.
I'm looking at page sources in an attempt to get the uname/passwd field names and populate them.
Here's the XML and command output. The strings seem fine based on those seen whel there's a successful and failed login. Case 1 can probably be eliminated since it just shows the login page can be displayed.
Any suggestions?
<testcasefile>login.prov.xml</testcasefile>
<useragent>WebInject Application Tester</useragent>
<timeout>10</timeout>
<globaltimeout>20</globaltimeout>
<comment>
<reporttype>nagios</reporttype>
</comment>
<reporttype>standard</reporttype>
<testcases repeat="1">
<comment>case 2 should probably be case 1 and the get an additional check after logging in--had it worked</comment>
<case
id="1"
description1="Connecting to Satellite"
method="get"
url="https://solktxeshgw-v-pmeprov-01/users/login"
parseresponse='mykey="|"'
verifypositive="Welcome to Satellite"
errormessage="Unable to connect to the Satellite login page"
<case
id="2"
description1="Authentication on Satellite"
method="post"
postbody="login_login=nagiosadmin&login_password=5t6y%T^Ygrid&mykey={PARSEDRESULT}"
verifynegative="Error: Incorrect username or password"
errormessage="Unable to authenticate user in Satellite"
</testcases>
$ ./webinject.pl --config login.prov.global.xml
Starting WebInject Engine...
Test: login.prov.xml - 1
Verify : "Welcome to Satellite"
Passed Positive Verification
Passed HTTP Response Code Verification (not in error range)
TEST CASE PASSED
Response Time = 0.123 sec
Use of uninitialized value in substitution (s///) at ./webinject.pl line 1148.
Test: login.prov.xml - 2
Verify Negative: "Error: Incorrect username or password"
Passed Negative Verification
Failed HTTP Response Code Verification (HTTP/1.1 400 Bad Request)
TEST CASE FAILED : Unable to authenticate user in Satellite
Response Time = 0.025 sec
Start Time: Wed Oct 3 21:36:48 2018
Total Run Time: 0.229 seconds
Test Cases Run: 2
Test Cases Passed: 1
Test Cases Failed: 1
Verifications Passed: 3
Verifications Failed: 1
