Gentoo switched from mysql shipped client libs to mysql-connector-c (https://dev.mysql.com/downloads/connector/c/). This causes two problems with check_mysql_query:
GDB tell me:/usr/lib64/nagios/plugins/check_mysql_query -q "SELECT CASE WHEN variable_value = 'ON' THEN 0 ELSE 2 END FROM information_schema.global_status WHERE variable_name='SLAVE_RUNNING'" -u munin -w 0 -c 1
Speicherzugriffsfehler (Speicherabzug geschrieben)
PID: 30491 (check_mysql_que)
UID: 0 (root)
GID: 0 (root)
Signal: 11 (SEGV)
Timestamp: Thu 2018-11-15 14:40:05 CET (2s ago)
Command Line: /usr/lib64/nagios/plugins/check_mysql_query -q SELECT CASE WHEN variable_value = 'ON' THEN 0 ELSE 2 END FROM information_schema.global_status WHERE variable_name='SLAVE_RUNNING' -u munin -w 0 -c 1
Executable: /usr/lib64/nagios/plugins/check_mysql_query
Control Group: /user.slice/user-1000.slice/session-584.scope
Unit: session-584.scope
Slice: user-1000.slice
Session: 584
Owner UID: 1000 (rhering)
Boot ID: 1402b547b1f842789ffb300c29f0e707
Machine ID: 4a6906c2152dff421b9b5a385455c64e
Hostname: alpha.mail
Storage: /var/lib/systemd/coredump/core.check_mysql_que.0.1402b547b1f842789ffb300c29f0e707.30491.1542289205000000.lz4
Message: Process 30491 (check_mysql_que) of user 0 dumped core.
Stack trace of thread 30491:
#0 0x00007f74fb668c47 memset (libcrypto.so.1.0.0)
#1 0x00007f74fc4741ca my_aes_decrypt (libmysqlclient.so.18)
#2 0x00007f74fc47063f n/a (libmysqlclient.so.18)
#3 0x00007f74fc470b45 n/a (libmysqlclient.so.18)
#4 0x00007f74fc470f6e my_search_option_files (libmysqlclient.so.18)
#5 0x00007f74fc471735 my_load_defaults (libmysqlclient.so.18)
#6 0x00007f74fc432ec8 mysql_read_default_options (libmysqlclient.so.18)
#7 0x00007f74fc43a3fc mysql_real_connect (libmysqlclient.so.18)
#8 0x00005571d9d80796 main (check_mysql_query)
#9 0x00007f74fbe33ae7 __libc_start_main (libc.so.6)
#10 0x00005571d9d80bfa _start (check_mysql_query)
GNU gdb (Gentoo 8.2 p1) 8.2
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://bugs.gentoo.org/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /usr/lib64/nagios/plugins/check_mysql_query...Reading symbols from /usr/lib64/debug//usr/lib64/nagios/plugins/check_mysql_query.debug...done.
done.
warning: core file may not match specified executable file.
[New LWP 30491]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Core was generated by `/usr/lib64/nagios/plugins/check_mysql_query -q SELECT CASE WHEN variable_value'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007f74fb668c47 in memset (__len=168, __ch=0, __dest=0x0) at /usr/include/bits/string_fortified.h:71
71 return __builtin___memset_chk (__dest, __ch, __len, __bos0 (__dest));
(gdb) bt
#1 EVP_CIPHER_CTX_init (ctx=0x0) at evp_enc.c:82
#2 0x00007f74fc4741ca in my_aes_decrypt () from /usr/lib64/libmysqlclient.so.18
#3 0x00007f74fc47063f in ?? () from /usr/lib64/libmysqlclient.so.18
#4 0x00007f74fc470b45 in ?? () from /usr/lib64/libmysqlclient.so.18
#5 0x00007f74fc470f6e in my_search_option_files () from /usr/lib64/libmysqlclient.so.18
#6 0x00007f74fc471735 in my_load_defaults () from /usr/lib64/libmysqlclient.so.18
#7 0x00007f74fc432ec8 in mysql_read_default_options () from /usr/lib64/libmysqlclient.so.18
#8 0x00007f74fc43a3fc in mysql_real_connect () from /usr/lib64/libmysqlclient.so.18
#9 0x00005571d9d80796 in main (argc=<optimized out>, argv=<optimized out>) at check_mysql_query.c:100---
2nd problem:
PID: 21044 (check_mysql_que)
UID: 0 (root)
GID: 0 (root)
Signal: 11 (SEGV)
Timestamp: Thu 2018-11-15 14:45:56 CET (3s ago)
Control Group: /user.slice/user-1000.slice/session-586.scope
Unit: session-586.scope
Session: 586
Storage: /var/lib/systemd/coredump/core.check_mysql_que.0.1402b547b1f842789ffb300c29f0e707.21044.1542289556000000.lz4
Message: Process 21044 (check_mysql_que) of user 0 dumped core.
Stack trace of thread 21044:
#0 0x00007f7f8a455613 __rawmemchr_avx2 (libc.so.6)
#1 0x00007f7f8a374192 _IO_str_init_static_internal (libc.so.6)
#2 0x00007f7f8a3643fd _IO_vsscanf (libc.so.6)
#3 0x00007f7f8a35d97c __sscanf (libc.so.6)
#4 0x000055ba80c114c8 is_numeric (check_mysql_query)
#5 0x000055ba80c1080a main (check_mysql_query)
#6 0x00007f7f8a311ae7 __libc_start_main (libc.so.6)
#7 0x000055ba80c10bfa _start (check_mysql_query)
done.
[New LWP 21044]
#0 __rawmemchr_avx2 () at ../sysdeps/x86_64/multiarch/memchr-avx2.S:61
61 VPCMPEQ (%rdi), %ymm0, %ymm1
(gdb) bt
#1 0x00007f7f8a374192 in _IO_str_init_static_internal (sf=sf@entry=0x7ffed8893cd0, ptr=ptr@entry=0x8f8f8f8f8f8f8f8f <error: Cannot access memory at address 0x8f8f8f8f8f8f8f8f>, size=size@entry=0, pstart=pstart@entry=0x0) at strops.c:41
#2 0x00007f7f8a3643fd in _IO_vsscanf (string=0x8f8f8f8f8f8f8f8f <error: Cannot access memory at address 0x8f8f8f8f8f8f8f8f>, format=0x55ba80c1805c "%f%c", args=args@entry=0x7ffed8893e00) at iovsscanf.c:40
#3 0x00007f7f8a35d97c in __sscanf (s=<optimized out>, format=format@entry=0x55ba80c1805c "%f%c") at sscanf.c:32
#4 0x000055ba80c114c8 in is_numeric (number=<optimized out>) at utils.c:245
#5 0x000055ba80c1080a in main (argc=<optimized out>, argv=<optimized out>) at check_mysql_query.c:148Code: Select all
diff -urN a/plugins/check_mysql_query.c b/plugins/check_mysql_query.c
--- a/plugins/check_mysql_query.c 2018-11-15 14:25:30.110775355 +0100
+++ b/plugins/check_mysql_query.c 2018-11-15 14:25:49.477436877 +0100
@@ -136,18 +136,18 @@
die (STATE_CRITICAL, "QUERY %s: Fetch row error - %s\n", _("CRITICAL"), error);
- /* free the result */
- mysql_free_result (res);
- /* close the connection */
- mysql_close (&mysql);
if (! is_numeric(row[0])) {
die (STATE_CRITICAL, "QUERY %s: %s - '%s'\n", _("CRITICAL"), _("Is not a numeric"), row[0]);
value = strtod(row[0], NULL);
+ /* free the result */
+ mysql_free_result (res);
+ /* close the connection */
+ mysql_close (&mysql);
if (verbose >= 3)
printf("mysql result: %f\n", value);dev-db/mysql-connector-c: 6.1.11-r1
dev-db/mysql: 5.7.23-r2
net-analyzer/nagius-plugins: 2.2.1-r3
