Windows CMD: wmic /node: "HOSTNAME" COMPUTERSYSTEM GET USERNAME
UserName
DOMAIN\USER
How does it work on Nagios? /check_wmi_plus.pl -H HOST -u domain/user -p password -m checkservice --extrawmicarg????
check_wmi_plus.pl USERS Last logon
Re: check_wmi_plus.pl USERS Last logon
What exactly do you mean "How does it work on Nagios?"
There is info here on the authors page
http://www.edcint.co.nz/checkwmiplus/?q=quickstart
You can find example commands here
http://www.edcint.co.nz/checkwmiplus/?q ... mmandlines
engmatecadmin
what I want is to read the last logonuser via wmi on the Windows client.
But i'm not able to because i did't find the rigth syntax for this comand with checkwmiplus.
To read out the Ip address or cpu is no problem.
Basically, is it possible to read out the last logon-user via checkwmiplus?
Thank you for help.
Regards
Thank you for help.
Regards
I'm not sure what the query would be, but to do this you would need to create a new check in the ini file that retrieved this information.
Here is the documentation on the Ini file
http://www.edcint.co.nz/checkwmiplus/?q ... esHeadPage
