I am running v5.5.3 64 bit VM CentOS 7.
I have a certificate and can connect to Nagios XI using a URL that starts with https://
I followed the instructions of a previous case:
Adding the following to the bottom of the ssl.conf file:
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{SERVER_NAME}/%$
Things improved, in that going to http://... worked.
However, the URL stays as http://... instead of changing to https://...
How can I tell if its really redirected?
Redirecting http to https
Bitflogger
Re: Redirecting http to https
I made it work by copying this to the end of the httpd.conf file and restarting with: sudo systemctl restart httpd.service
<VirtualHost nagiosxi.doit.wisc.edu:80>
RedirectMatch (.*)$ https://nagiosxi.doit.wisc.edu$1
</VirtualHost>
Are the changes to ssl.conf still necessary ?
</VirtualHost>
https://assets.nagios.com/downloads/nag ... s%20XI.pdf covers the necessary changes for httpd.conf, ssl.conf as well as other places where things need to be tweaked.
Bitflogger
The linked doc helped, it works now. Please lock.
Earl
Earl
