Hello Team,
I am looking for an opensource dashboard which can integrate with Nagios XI. The data source will be from Nagios and we can use the data to create the customized dashboard.
I had looked into to Graphana, Freeboard, and another available tool. Please suggest a similar tool which works with Nagios.
Regards...
Dashboard tool compatabile with Nagios
Re: Dashboard tool compatabile with Nagios
It will depend on what you are looking to see, but there is a guide on our KB for integrating Grafana into Nagios XI
https://support.nagios.com/kb/article/n ... a-805.html
Thank you Scott. I was also looking at Nagvis which was already available in Nagios XI. When I click on Nagvis under Maps it asks for username and password.
Not sure if that was done during the initial setup of the tool. Can you give me some documentation around on setting up Nagvis.
Thank you..
Regards...
Thank you..
Regards...
What version of XI are you running?naranant wrote:Thank you Scott. I was also looking at Nagvis which was already available in Nagios XI. When I click on Nagvis under Maps it asks for username and password.
Thank you..
Regards...
In older versions only the nagiosadmin user was setup by default in NagVis but in 5.5.x it should auto login admin users
the version is 5.4.13
Regards.
Regards.
You should be able to login with the nagiosadmin username/password
thank you I was able to access it.. Please let me know if any documentation on modifying the map both in terms of data source as well as the background look
The documentation is builtin under the "Need Help?" menunaranant wrote:thank you I was able to access it.. Please let me know if any documentation on modifying the map both in terms of data source as well as the background look
