Formatting text messages?
t3dus
Post by t3dus »
Is there a special way to format my sms messages from Nagios Core?
Currently if I have them text me they show up as 3 separate messages vs 1 which is super annoying so I simply don't have them going there at all which is a big issue as far as seeing alerts right away.
Re: Formatting text messages?
Post by mcapra »
It would probably depend on the specific messaging service you're using. I don't have this problem with Twilio:
My implementation:
https://support.nagios.com/forum/viewto ... 94#p252294
t3dus
Post by t3dus »
I simply have nagios core e-mailing my phone through the provided e-mail to text provided by my phone provider.
Since I currently use US Cellular it looks something like "[email protected]" which then sends e-mails to me via text.
I'm not sure i'd be interested in using something like Twilio that costs money.
What I am asking is if there is someway to format the e-mails to be shorter within nagios config files
ssax
Dreams In Code
Post by ssax »
If you want to shorten the message you may want to create a separate contact for SMS and then set the contacts host/service_notification_handler_commands to new commands that only sends what you want:
From the default:
        command_name    notify-host-by-email
        command_line    /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
        command_name    notify-service-by-email
        command_line    /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
To a custom command:
        command_name    notify-host-by-sms
        command_name    notify-service-by-sms
Unfortunately, we'd need to know where your SMS provider is splitting the messages in order to determine what to change in the custom commands but that's how you'd do it.
cdienger
Post by cdienger »
Notification command definitions are in /usr/local/nagios/etc/objects/commands.cfg by default and these dictate the format. The notify-host-by-email andnotify-service-by-email definitions for example:
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/sbin/sendmail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /usr/sbin/sendmail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
Information on macros that can be used can be found at https://assets.nagios.com/downloads/nag ... olist.html
