Dummy object using up License
nagiosEngie
Post by nagiosEngie »
Hello Nagios Crew,
I have created some dummy objects as parents to my servers. All dummy objects are created with different names but all point to 127.0.0.1.
This has been done so that in the Maps I have the dummy object with the relative severs under it like in image map01.jpg.
My problem is that these objects take away 1 license each and I was wondering if there was a method to avoid this.
Sandro
Re: Dummy object using up License
If they have a unique hostname they will use up one of the licenses, there is no way around this.
nagiosEngie
Hello Scott,
this can be considered closed.
++Thanks
Sandro
