HI All,
I have installed SNMP services and configured community strings, however I cannot monitor windows hosts using windows snmp wizard. I can do snmp walk on the host. There are no connection restriction configured. Please assist.
Windows monitoring with SNMP
Re: Windows monitoring with SNMP
What is the windows version that you are using? Did you check the snmp security settings?
For example, in Windows 7 you would go to:
Start->Search box->services.msc->Enter->Right-click on SNMP Service->Properties->Security tab
- Accepted community names->Add->your_community_string
- Accept SNMP packets from these hosts->Add->your_Nagios_server_IP_address
or you can use "Accept SNMP packets from any host" (not recommended).
Apply. Restart the SNMP service.
If it doesn't work, try re-running the wizard. In step 2, don't enter anything under SNMP Authentication (leave defaults) until you get it going.
Hope this helps.
Hope this helps.
