Removal of Host from NagiosXI with REST API
emartine
Post by emartine »
Is it possible to remove a host or service that is part of an escalation group from the REST API level?
What would be the correct procedure?
cdienger
Re: Removal of Host from NagiosXI with REST API
Post by cdienger »
Once a host or service is part of an escalation config, it cannot be removed via the API. It would need to be removed from the escalation config via the web UI before it can be deleted via the API or web UI.
