NRPE or NCPA
Dzonii
NRPE or NCPA
Post by Dzonii »
Hello to everyone, i wanna to monitor couple hosts with Nagios Core Server (only CPU and HD services ). Which solution is best and more simple for me to install NRPE or NCPA, or there is maybe another way to achieve this. Thx in advance
Re: NRPE or NCPA
NCPA is more and more becoming the defacto standard agent for Nagios, works on many more OS's and is easy to install.
https://www.nagios.org/ncpa/
Dzonii
Re: NRPE or NCPA
Post by Dzonii »
I download it arleady, and how to configure it ? Do i have to download NRPE on both sides or only on agent ? Thank you so much.
Re: NRPE or NCPA
Dzonii wrote:I download it arleady, and how to configure it ?
You downloaded NCPA? there is a setup guide under documentation section here
https://www.nagios.org/ncpa/#docs
Dzonii wrote:Do i have to download NRPE on both sides or only on agent ?
You need to download /install a plugin on the Nagios server for either agent NRPE or NCPA
More info
https://www.nagios.org/ncpa/getting-started.php
Dzonii
Re: NRPE or NCPA
Post by Dzonii »
Thank you so much @ scottwilkerson for your answer. I used NRPE and configured to monitor hdd, it work fine, now i wanna know will i get automatically alert when my hdd is full ? or should i configure that
Re: NRPE or NCPA
Dzonii wrote:Thank you so much @ scottwilkerson for your answer. I used NRPE and configured to monitor hdd, it work fine, now i wanna know will i get automatically alert when my hdd is full ? or should i configure that
You will if you set warning and critical levels when you configured your check.
