NRPE not working (SSL-Handshake)
freakazoid
Post by freakazoid »
I am using Ubuntu Server 18.04 and have installed Nagios Core 4.4.2 (following this manual https://www.itzgeek.com/how-tos/linux/u ... 16-04.html).
and NRPE (following this manual https://www.itzgeek.com/how-tos/linux/c ... ios-3.html)
IP: x.x.x.3/24 (same subnet as Windows Example host)
Moreover I have Windows 2016 Server which is my example host. On this Win-Server I have installed NSCP-0.5.2.35-Win32.msi.
IP: x.x.x.20/24 (same subnet as Nagios Server)
My nsclient.ini is attached to this post.
The check_nt-checks are working fine.
Problem:
I am not able to use nrpe-checks.
Error-messages:
NAGIOS-WEBFRONTEND
"CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with x.x.x.20: 1"
NAGIOS-Server
"check_nrpe -H x.x.x.20"
--> CHECK_NRPE (ssl_err !=5) Error - could not complete SSL handshake with x.x.x.20:1"
I reinstalled this server 3 times and checked several nsclient-configurations but it didn't work.
Can anyone help me please? I am thankful for any ideas / suggestions
best wishes,
freakazoid
nsclient.ini
nsclient.ini
(1.18 KiB) Downloaded 835 times
Re: NRPE not working (SSL-Handshake)
I think in your [/settings/NRPE/server] section you want to add
use ssl = 1
Then restart nsclient++
freakazoid
Thanks for the super fast reply.
I added "use ssl = 1" to the ini-file on the windows host.
When I check on the nagios-server ("check_nrpe -H <IP>.20"), I receive the same error message:
"CHECK_NRPE: (ssl_err !=5) Error - Could not complete SSL handshae with <IP>.20: 1"
Any other ideas?
best wishes,
freakazoid
freakazoid
I added
level = debug
And did a "Check_nrpe -H <IP>"
I received this in the logs
eroor:c:\source\master\include\socket/connection.hpp:276: Failed to establish secure connection: sslv3 alert handshake failure 1040
freakazoid
are there any ideas / any suggestions?
Can anyone tell me how to analyze the problem so that I can find a solution by myself?
Thanks in advance.
Best wishes,
freakazoid
Edit the nsclient.ini file again and under this section
Add these options.
ssl options =
allow arguments = true
allow nasty characters = true
port = 5666
extended response = 1
Save the changes and restart the nsclient++ agent and let us know it this works.
Without the enpty ssl option settings, I think the Nsclient++ agent is selecting an incompatible ssl setting for the plugin.
The other options are needed for accepting arguments, etc...
freakazoid
Thank you for your response.
I added the lines to the ini-file, yet the response is still the same
CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with <HOST_IP>: 1
Do you need any other information?
Can you post the nsclient.ini file and the nsclient.log file from this folder on the Windows system?
C:\Program Files\NSClient++
freakazoid
Thank you for your Reply.
Attached the two needed files.
nsclient.log
(82.72 KiB) Downloaded 922 times
nsclient.ini
(1.32 KiB) Downloaded 964 times
I would reinstall the check_nrpe plugin on the Nagios server using the following source installation instructions.
https://support.nagios.com/kb/article.php?id=515
At the bottom of the page, look for the following section.
Installing The Nagios Plugins
I feel that the plugin you currently have installed, may not have SSL enabled so it will have to be recompiled.
