check table on Microsoft SQL server
bashar.abed
Post by bashar.abed »
we have nagios XI version 5.4.13 VM machine
We are writing the log into table on Microsoft SQL Server , and we need to have alert on some logs if appears
there is wizard or services on Nagios system to check above option
Re: check table on Microsoft SQL server
You could use the MSSQL Query Wizard and write a simple query to select the count on the table in question
select (*) from table
Set your warning and critical levels to alert if the threshold is breached
