Accidentally erased Nagios Database
japscp
Post by japscp »
Hi guys,
Counting on your help to solve this question since I can't find the answer by myself.
As the subject says, I accidentally erased Nagios Database from /var/lib/mysql/ and can't find a way to restore/install it again.
Can you help me solve this?
Thank you.
benjaminsmith
Re: Accidentally erased Nagios Database
Post by benjaminsmith »
Are your using Nagios Core or Nagios XI? This is the Core forum and there is not a database back-end by default. Let me know your setup and installation. Thanks.
japscp
Post by japscp »
I'm using Core.
It's not that it prevents nagios from working, but from what I realize the pnp4nagios graphing service uses these databases, correct?
japscp wrote:Hi,
I'm using Core.
pnp4nagios does not used mysql databases, it used RRD files, it does not use any databases in /var/lib/mysql
