I am upgrading my Nagios server at our DR site and I get the following error.
Error Downloading Packages:
perl-Math-Calc-Units-1.07-6.el6.noarch: failure: perl-Math-Calc-Units-1.07-6.el6.noarch.rpm from epel: [Errno 256] No more mirrors to try.
perl-Number-Format-1.73-3.el6.noarch: failure: perl-Number-Format-1.73-3.el6.noarch.rpm from epel: [Errno 256] No more mirrors to try.
What can I do to fix this error.
Ed
Error doing a upgrade nagiopsxi
benjaminsmith
Re: Error doing a upgrade nagiopsxi
Hi @eddiez
Do you get this error upgrading Nagios XI or upgrading the server itself?
If this is a server issue, the following article from Redhat may help you resolve this error.
https://access.redhat.com/solutions/203603
Let me know if you get it resolved.
This is what I did:
wget -O upgrade.sh https://assets.nagios.com/downloads/nagiosxi/upgrade.sh
sh ./upgrade.sh
After awhile I received the error
sh ./upgrade.sh
I removed the repo's that was listed in the artical and re-ran the upgrade, here is part of the output:
/Nagios-Monitoring-Plugin-Range.t line 28.
# Looks like you planned 151 tests but ran 1.
# Looks like you failed 1 test of 1 run.
# Looks like your test exited with 255 just after 1.
t/Nagios-Monitoring-Plugin-Range.t ...........
Dubious, test returned 255 (wstat 65280, 0xff00)
Failed 151/151 subtests
# Failed test 'use Nagios::Monitoring::Plugin::Threshold;'
# at t/Nagios-Monitoring-Plugin-Threshold.t line 5.
# Tried to use 'Nagios::Monitoring::Plugin::Threshold'.
# Error: Base class package "Class::Accessor::Fast" is empty.
# (Perhaps you need to 'use' the module which defines that package first,
# or make that module available in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .).
# at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Threshold.pm line 8
# BEGIN failed--compilation aborted at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Threshold.pm line 8.
# Compilation failed in require at (eval 4) line 2.
# BEGIN failed--compilation aborted at (eval 4) line 2.
Can't locate object method "set_thresholds" via package "Nagios::Monitoring::Plugin::Threshold" at t/Nagios-Monitoring-Plugin-Threshold.t line 18.
# Looks like you planned 93 tests but ran 2.
# Looks like you failed 1 test of 2 run.
# Looks like your test exited with 255 just after 2.
Failed 14/16 test programs. 39/190 subtests failed.
t/Nagios-Monitoring-Plugin-Threshold.t .......
Failed 92/93 subtests
Test Summary Report
t/check_stuff.t (Wstat: 3328 Tests: 14 Failed: 13)
Failed tests: 1-10, 12-14
Non-zero exit status: 13
t/Nagios-Monitoring-Plugin-01.t (Wstat: 65280 Tests: 1 Failed: 1)
Failed test: 1
Non-zero exit status: 255
Parse errors: Bad plan. You planned 15 tests but ran 1.
t/Nagios-Monitoring-Plugin-02.t (Wstat: 65280 Tests: 1 Failed: 1)
Failed test: 1
Parse errors: Bad plan. You planned 103 tests but ran 1.
t/Nagios-Monitoring-Plugin-03.t (Wstat: 65280 Tests: 2 Failed: 1)
Failed test: 1
Parse errors: Bad plan. You planned 61 tests but ran 2.
t/Nagios-Monitoring-Plugin-04.t (Wstat: 65280 Tests: 2 Failed: 2)
Failed tests: 1-2
Parse errors: Bad plan. You planned 30 tests but ran 2.
t/Nagios-Monitoring-Plugin-Functions-01.t (Wstat: 2560 Tests: 113 Failed: 10)
Failed tests: 2-11
Non-zero exit status: 10
t/Nagios-Monitoring-Plugin-Getopt-01.t (Wstat: 65280 Tests: 1 Failed: 1)
Failed test: 1
Parse errors: Bad plan. You planned 76 tests but ran 1.
t/Nagios-Monitoring-Plugin-Getopt-02.t (Wstat: 65280 Tests: 1 Failed: 1)
Failed test: 1
Parse errors: Bad plan. You planned 14 tests but ran 1.
t/Nagios-Monitoring-Plugin-Getopt-03.t (Wstat: 65280 Tests: 1 Failed: 1)
Failed test: 1
t/Nagios-Monitoring-Plugin-Getopt-04.t (Wstat: 65280 Tests: 1 Failed: 1)
Failed test: 1
Parse errors: Bad plan. You planned 11 tests but ran 1.
t/Nagios-Monitoring-Plugin-Performance-02.t (Wstat: 1024 Tests: 4 Failed: 4)
Failed tests: 1-4
Non-zero exit status: 4
Parse errors: Bad plan. You planned 3 tests but ran 4.
t/Nagios-Monitoring-Plugin-Performance.t (Wstat: 65280 Tests: 1 Failed: 1)
Failed test: 1
Parse errors: Bad plan. You planned 231 tests but ran 1.
t/Nagios-Monitoring-Plugin-Range.t (Wstat: 65280 Tests: 1 Failed: 1)
Failed test: 1
Parse errors: Bad plan. You planned 151 tests but ran 1.
t/Nagios-Monitoring-Plugin-Threshold.t (Wstat: 65280 Tests: 2 Failed: 1)
Failed test: 1
Parse errors: Bad plan. You planned 93 tests but ran 2.
Files=16, Tests=190, 2 wallclock secs ( 0.13 usr 0.07 sys + 1.30 cusr 0.43 csys = 1.93 CPU)
Result: FAIL
make: *** [test_dynamic] Error 255
Test Summary Report
Failed test: 1
Failed test: 1
Failed test: 1
Failed tests: 1-2
Failed tests: 2-11
Failed test: 1
Failed test: 1
Failed test: 1
Failed test: 1
Failed tests: 1-4
Failed test: 1
Failed test: 1
Failed test: 1
Result: FAIL
What is the version of Nagios XI that you are upgrading from? Are you using a proxy or local repos?
Can you run the following commands, and show the output?
Also, post the entire upgrade.log.
yum clean all
yum repolist -vBe sure to check out our Knowledgebase for helpful articles and solutions!
[root@utlr1362 ~]# yum clean all
Loaded plugins: fastestmirror, refresh-packagekit, security
Cleaning repos: nagios-base nagiosxi-deps
Cleaning up Everything
Cleaning up list of fastest mirrors
[root@utlr1362 ~]# yum repolist -v
Loading "fastestmirror" plugin
Loading "refresh-packagekit" plugin
Loading "security" plugin
Config time: 0.017
Yum Version: 3.2.29
Determining fastest mirrors
nagios-base | 1.5 kB 00:00
nagios-base/primary | 18 kB 00:00
nagios-base 177/177
nagiosxi-deps | 1.5 kB 00:00
nagiosxi-deps/primary | 10 kB 00:00
nagiosxi-deps 33/33
Setting up Package Sacks
pkgsack time: 0.009
Repo-id : nagios-base
Repo-name : Nagios
Repo-revision: 1539383761
Repo-updated : Fri Oct 12 17:36:17 2018
Repo-pkgs : 177
Repo-size : 1.3 G
Repo-baseurl : http://repo.nagios.com/nagios/6/
Repo-expire : 21,600 second(s) (last: Tue Oct 16 10:23:31 2018)
Repo-id : nagiosxi-deps
Repo-name : Nagios XI Dependencies
Repo-revision: 1539383818
Repo-updated : Fri Oct 12 17:36:59 2018
Repo-pkgs : 33
Repo-size : 13 M
Repo-baseurl : http://repo.nagios.com/nagiosxi-deps/6/
repolist: 210
Current version : Nagios XI 2014R2.5
Config time: 0.017
Yum Version: 3.2.29
nagios-base 177/177
nagiosxi-deps 33/33
pkgsack time: 0.009
Repo-name : Nagios
Repo-pkgs : 177
Repo-size : 1.3 G
Repo-pkgs : 33
Repo-size : 13 M
repolist: 210
It seems like that you did a rpm install of Nagios XI, but now you are trying to use an upgrade script, used for source installs. This is not going to work... In order to upgrade your Nagios XI instance, you would need to run:
Let us know if this helped. Thank you!
yum update nagiosxiBe sure to check out our Knowledgebase for helpful articles and solutions!
